WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
Old 06-11-2006, 08:47 PM
grabbem88
grabbem88's Avatar
Default WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
a couple of days ago i decided to unplug my V.S.S ...
the car's idle doesn't hang up no more.
doesn't jump around,and try to die...
i just don't think my my car needs this(my tuner said i did ) i have replaced it twice thinking it was faulty..
my car was converted 5yrs ago to mass air,and was told to have it hooked up,cause mass air car's require this????i took it was for auto cars and cruise equiped cars.
grabbem88 is offline
Old 06-11-2006, 09:03 PM
TENGRAM
TENGRAM's Avatar
Default RE: WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
ORIGINAL: grabbem88
the ecm uses the vss for load calculations to determine optimal timing and fuel enrichment. with it disconnected you may have problems.
TENGRAM is offline
Old 06-11-2006, 09:12 PM
grabbem88
grabbem88's Avatar
iv'e heard it's not a must though....now that it is unplugged it runs perfect(considering my set up)
see my car never had this...i had to go to junk yard to get the peices.
Old 06-12-2006, 03:57 PM
grabbem88
grabbem88's Avatar
anybody else?..
Old 06-12-2006, 04:10 PM
Sprayin86
Sprayin86's Avatar
I'm no expert but I just converted mine and didn't add the vss. (only because money was tight) I've had no problems as of yet. Mine is also a 5 speed.
Sprayin86 is offline
Old 06-12-2006, 04:13 PM
grabbem88
grabbem88's Avatar
i know now when i come to stop sign and push the clutch in the rpms drop quicker.
kinda annoying,but not as bad as idle going up/down constantly...
btw way sprayn86 is that an 87 T....or did you swap front ends?...looks nice.
Old 06-12-2006, 04:22 PM
Joel5.0
Joel5.0's Avatar
Like TENGRAM said....you may have "solved" the idle problem by eliminating an input used for idle control, load, etc.....think of it as forcing the ECM to run an alternate strategy w/out the VSS input, and not allow the system to compensate....you may want to check this write-up article though.
Joel5.0 is offline
Old 06-12-2006, 04:30 PM
grabbem88
grabbem88's Avatar
well i plugged it back in...i did notice it's really close to my midpipe....remember my car can heat a two family house all winter long..
i can live with the idle interuption i guess....just gets annoying.
Old 06-12-2006, 05:19 PM
Sprayin86
Sprayin86's Avatar
Nope, its an 86. The body and interior have been swapped over to 87-93 specific.
ORIGINAL: grabbem88
Old 06-12-2006, 05:29 PM
grabbem88
grabbem88's Avatar
good job then...i know how much a pita that is to convert...if you want it to line up perfect..
Quick Reply: WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
