Now Bad News plz help
Old 06-13-2006, 10:39 AM
kevstang87
kevstang87's Avatar
Default RE: Good And Bad News
AFTER YOU DRAIN YOUR OIL(BOTH PLUGS) YOUR MUSTANG(302) WILL TAKE 5 QUARTS OF OIL, NO MORE NO LESS.
kevstang87 is offline
Old 06-13-2006, 10:43 AM
grabbem88
grabbem88's Avatar
the shaking could be from a tire..or a balancer...u-joint rear inner wheel bearings...proccess of elimination
grabbem88 is offline
Old 06-13-2006, 10:45 AM
ttoppedaerocoupe
ttoppedaerocoupe's Avatar
no offense grabbem, but why would a tire, u joint, or wheel bearing cause the car to shake at idle?
alex
ttoppedaerocoupe is offline
Old 06-13-2006, 10:46 AM
grabbem88
grabbem88's Avatar
because i didn't read that far[8D]...i skim too much
ORIGINAL: ttoppedaerocoupe
alex
Old 06-13-2006, 10:51 AM
grabbem88
grabbem88's Avatar
i will add this though..while you are fixing your oil problem check your motor mounts also..
Old 06-13-2006, 03:02 PM
ttoppedaerocoupe
i just read my post from before, i didnt mean to make it sound like you were an idiot, sorry grabbem. Im at work and I wasnt really payin attention to what I was typing. No hard feelings i hope.
+1 for checking your motor mounts tho. Any mods in the future you plan on making will go A LOT smoother with good mounts. (ask anyone with ah*tty mounts about long tube headers rubbing.)
alex
Old 06-13-2006, 07:04 PM
88 rubber eater
88 rubber eater's Avatar
Ok Ill try the tune-up, I didnt even think about that. Do you guys think I should change my oil again too? thats for the help guys.
88 rubber eater is offline
Old 06-13-2006, 08:17 PM
5.0stanger
5.0stanger's Avatar
It will take 5 quarts with a filter change 4 quarts with out a filter. I would just drain some more out or take off the filter and drain that..will be about a quart, wouldn't drain it all. I think you should check you PCV if it looks like oil is comming up your dipstick tube...
5.0stanger is offline
Old 06-13-2006, 08:20 PM
white93 GT
white93 GT's Avatar
my dipstick has always read really high. i think at the f in full.
i rebuilt my motor and put in exactly 5 quarts and it still read to the f on full which is way past all the other stuff
white93 GT is offline
Old 06-13-2006, 08:53 PM
Twisted
Twisted's Avatar
ORIGINAL: white93 GT
In my experience, the F is the "full mark"--or rather just below it.
Twisted is offline
Quick Reply: Now Bad News plz help
