Hellion Turbo Kit, AFR 185's, BBK SSI
Old 06-14-2006, 12:43 PM
r.barn
r.barn's Avatar
Default RE: Hellion Turbo Kit, AFR 185's, BBK SSI
run dish pistons and you can run a real aggressive timing curve, that will help
also www.snowperformance.com, this would allow to you run an even more aggressive timing
in the hellion artcl they got 465rwhp off 185's, TFS intake, stock cam and stock exhasut
remember also that they were in NewMexico at an altitude of probably 3,000'
if you're at lower altitude it will make more power.
with 185's, good intake, good cam and exhaust.... you should push 500rwhp.
you can always do somethings like........underdrive pullies, electric fan, windage tray ..... those things togther will add another 20 or so hp.
personally I'm going with the following set-up and plan on putting it in the shop for engine
rebuild at end of the month.
306 overbore rebuild with forged dish pitson and windage tray and girdle support
Thumper ported stock heads
Ford "F" cam
Trickflow intake
70mm TB
underdrive pullies
electric fan
Figuring this should get me right at 500rwhp.
r.barn is offline
Old 06-14-2006, 12:55 PM
88BlueGT
88BlueGT's Avatar
^^^ And you going to use a Hellion w/ that setup?
88BlueGT is offline
Old 06-14-2006, 12:56 PM
myshifter
I ♥ Acer
myshifter's Avatar
people are gonna be so mad when the block cracks in half.
myshifter is offline
Old 06-14-2006, 01:01 PM
r.barn
r.barn's Avatar
whats life with out a little danger, lol ......
ORIGINAL: myshifter
r.barn is offline
Old 06-14-2006, 01:02 PM
r.barn
r.barn's Avatar
yes, car goes in for engine rebuild in about 2 weeks
ORIGINAL: 88BlueGT
r.barn is offline
Old 06-14-2006, 01:42 PM
88BlueGT
88BlueGT's Avatar
Lucky B.... I'm killing myself financially just to get a set of gears
88BlueGT is offline
Old 06-14-2006, 02:05 PM
r.barn
r.barn's Avatar
I'm 33 so it comes with being old and having a good job, lol
ORIGINAL: 88BlueGT
r.barn is offline
Old 06-14-2006, 02:07 PM
88BlueGT
88BlueGT's Avatar
Ohhhhhhhhh Well that explains alot Im 18 and about 11k in loans already.........[:@][&:]
88BlueGT is offline
Old 06-14-2006, 02:35 PM
r.barn
r.barn's Avatar
ROFL!!!........ between my house and my plane I have 100's of thousands in loans, just wait.........
ORIGINAL: 88BlueGT
r.barn is offline
Old 06-14-2006, 02:49 PM
JBradley500
JBradley500's Avatar
347???
JBradley500 is offline
Quick Reply: Hellion Turbo Kit, AFR 185's, BBK SSI
