MSD Blaster TFI IV Coil, please help!
Old 06-17-2006, 07:24 PM
Dearborn5.0
Dearborn5.0's Avatar
Default MSD Blaster TFI IV Coil, please help!
Someone who has a great running car, and MSD Blaster TFI Coil, please take the
resistance across the primary and secondary side of the coil and let me know the values. I think my coil is bad.
What i mean is....take a voltmeter, put it on ohms, remove the connector with the little wires (primary) and read the ohms in from the + to the -
Then take the 8mm (big) ignition wire off, and measure resistance from the big post to the battery negative terminal. (secondary)
Please reply with your numbers.
Please more than 1 person apply.
Background
I'm getting no spark. Tested coil wire, ok. (3K ohms) grounded coil wire & spark plug (to valve cover) while cranking, no spark.
Put ignition in run position, grounded coil manually to battery neg, got a spark to
jump from coil primary negative to battery post neg.
I think my coil has shorted itself . Please reply with ohm values.
Dearborn5.0 is offline
Old 06-17-2006, 07:46 PM
silver91gt
silver91gt's Avatar
Default RE: MSD Blaster TFI IV Coil, please help!
around 8000 ohms between the positive and negative plug terminals
and from the plug terminal to the spark plug part it is 7 ohms
silver91gt is offline
Old 06-17-2006, 08:04 PM
silver91gt
silver91gt's Avatar
or mabye its the other way around, I did it last week.
Old 06-18-2006, 04:18 AM
Dearborn5.0
Thanks silver. Anyone get the same?
Old 06-26-2006, 03:23 PM
Dearborn5.0
Follow-up: My coil checked with silver and MSD specs on MSD's website.
Turns out the TFI module went bad. The coil was okay.
MSD replied to my question by saying "replace your old coil with theses new MSD products...." The did not answer my question. Idiots. [:'(]
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
firehorse02
11-16-2015 11:28 AM
Sixer4Life
09-28-2015 07:05 AM
lmurf60
09-24-2015 10:07 PM
Quick Reply: MSD Blaster TFI IV Coil, please help!
