Sound Clip of X/Z Cam?
Old 07-12-2006, 05:35 PM
  #21
88BlueGT
88BlueGT's Avatar
Default RE: Sound Clip of X/Z Cam?
If you want a soundclip search streetfire
88BlueGT is offline
Old 07-12-2006, 06:06 PM
  #22
Joel5.0
Joel5.0's Avatar
ORIGINAL: ckyguy68
but would they need to be notched for AFR or TW heads?
ORIGINAL: Joel5.0
The X-303 is literally a B-303 with more lift....it works OK with the right support (fuel, compression or forced induction), and it sounds great. Had mine in there for 13 yrs. now, daily driver too. Pistons had to be notched though....and the Z-303 would require it too due to the higher overlap.
Z-303....most likely with either set....X-303...yes w/AFR....need to check with TW's.....the point is, need to do a PtV check anyway...insurance that pays off, check http://sbftech.com/index.php/topic,354.0.html ....FYI
Joel5.0 is offline
AmericanMuscle4.6GT
11-10-2015 02:06 PM
Big Al's 03
Mach 1 Section
09-21-2015 07:59 AM
uberstang1
09-20-2015 06:42 PM
EASTIDEE123
09-14-2015 03:52 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: Sound Clip of X/Z Cam?
