Paint? Motor?
Old 06-12-2003, 11:28 AM
89muscle
89muscle's Avatar
Default Paint? Motor?
i need help. i want to paint my car cause it has some minor dings and chips but its still in good shape. either make it a cobra or a saleen body kit with cobra-r rims, or rebuild my motor with the trickflow heads, systemax inake, 1.6 cobra rr, e303, fel-pro rebuild kit, and the rest of the minor stuff with the rebuild. i have a rear main seal that is leaking pretty good but i dont wanna take it out and change it untill the motor is out. any questions?
89muscle is offline
Old 06-12-2003, 11:29 AM
89muscle
89muscle's Avatar
and suggestions?
89muscle is offline
Old 06-12-2003, 11:46 AM
DrededSS
DrededSS's Avatar
Engine all the way. Being an '89, I wouldn't add a body kit. I'd simply clean up the lines, get a good paintjob, and add the cobra wheels. I came across this same dilemma last semester. I could either build my engine and add a posi, or get a paintjob and rims. I opted for the engine and posi, and I don't regret it one bit. I've saved up to this point, and now it's about to go to the bodyshop. Then it will come home to be dropped with the Belltech and doetsch tech parts laying in my closet.</P>
Dred</P>
DrededSS is offline
Old 06-12-2003, 11:54 AM
WhiteHawk
WhiteHawk's Avatar
Definitely motor dude. We are guys.....screw the paint, get the car running how you envision it, suspension, engine, integral structure, braking, patch contact, then after all that if you still wish to do the paint.....then do that....but all else should come first.
WhiteHawk is offline
Old 06-12-2003, 02:17 PM
Jameasun
Jameasun's Avatar
I really like ugly cars that whip the pretty boys a$$es! Get the engine work done first. Then again I might just be a hick.<img border="0" src=smileys/smiley2.gif border="0">
Jameasun is offline
Old 06-12-2003, 02:42 PM
89muscle
89muscle's Avatar
well the car is pretty hott i got the running horse on the back window with 8% tint all round. its deep blue metallic perl. with the ground f-x emblems. Silver Metallic. but it has silver prime rims that are in good shape except 1 that is marked up pretty good. wut about cams. i want the f- but my friend has it and its alil to shaky for the street. i need something better than the e but not as much as the f. any suggestions? and edelbrock rpm 2 or systemax. the edelbrock is brand new
89muscle is offline
Old 06-12-2003, 05:39 PM
89muscle
89muscle's Avatar
im talking about the intakes for the edelbrock rpm 2 and the systemax 2 upper and lower intake pleniums
89muscle is offline
Old 06-12-2003, 06:14 PM
Sean
Sean's Avatar
I know for sure I am no hick,and would also say engine mods should most definitelty come first.As far as intakes I went with the T/F track heat because I have heard more posotive info from people who have used all three.Wanted the systemax II but ended up with the T/F,it is also cheaper.
Sean is offline
Old 06-12-2003, 11:21 PM
DrededSS
DrededSS's Avatar
Someone is going to have to explain the cam talk on this board...e? f?</P>
I'm used to 268 or 274, etc...</P>
Dred</P>
DrededSS is offline
Old 06-12-2003, 11:30 PM
Snake
Snake's Avatar
They are just different cams made by ford for performance. E303, B303, F303, and i think there's even an X303 but i could be wrong. As far as the individual numbers on these, I have no clue, but i'm sure someone here does. </P>
Snake is offline
Quick Reply: Paint? Motor?
