What heads would go best with current setup
Old 06-06-2004, 12:26 PM
  #21
callmecobra
callmecobra's Avatar
Default RE: What heads would go best with current setup
canfield=$$$$
callmecobra is offline
Old 06-06-2004, 06:36 PM
  #22
D1g1tal V3n0m
I ♥ Acer
D1g1tal V3n0m's Avatar
That's what I said biotch!
D1g1tal V3n0m is offline
Old 06-06-2004, 06:43 PM
  #23
Obsol3te
Obsol3te's Avatar
ORIGINAL: D1g1tal V3n0m
Canfield's make the best heads for the 5.0 but are very very expensive and not easy to find.
AFR makes a great head also. I've seen tests between the AFR and the Canfields and the Canfields edged them out every time. But anyway....
You're going to want a AFR 185 for a 331 or higher (351W or higher get the 205s). 165's for a 302. The problem you're running into is you're getting ahead of yourself. Getting the AFR 185s at this point would probably hinder performance but would save you money in the long run. 165s would give the best power gains at this point HOWEVER when you stroke it won't give the best gains at that point so you will be wanting a bigger head and dishing out more money. Don't get any of the GT-40 type heads. Horrible compared to others. The GT-40Ps are if you're on a budget however with that you're going to need new headers.
You have to decide what's more important to you and what goals you're going to acheive with the motor. I personally say get it stroked and new heads at the same time.
As for horsepower gains I'd say expect to see anywhere from 50-60+rwhp depending on tuning etc.
Really?
the dyno place said i should expect atleast an 80HP gain out of the edels with whats currently in the car
Obsol3te is offline
Old 06-06-2004, 06:51 PM
  #24
callmecobra
ORIGINAL: Obsol3te
Really?
nah, if you were blown or stroked, yeah.
Old 06-06-2004, 06:52 PM
  #25
Obsol3te
Obsol3te's Avatar
damn, was excited too...
Obsol3te is offline
Old 06-06-2004, 07:00 PM
  #26
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
canefields alittle much imo for a street car - something like afr or edlebrock would be better on a daily driver - would definately perform better in the idle - 6k ~ range over the canefields - which are low velocity heads - not good unless your really winding up
mdvaldosta is offline
Old 06-06-2004, 07:03 PM
  #27
Obsol3te
Obsol3te's Avatar
Are the AFR 165's worth the $400-$500 difference tho between the Edelbrock Performer RPM ?
Obsol3te is offline
Old 06-06-2004, 07:07 PM
  #28
mdvaldosta
I ♥ Acer
mdvaldosta's Avatar
If you're just looking for a cheap set of performance heads, check eBay. I just looked and I already saw this
http://cgi.ebay.com/ebaymotors/ws/eB...category=33617
and Im sure theirs alot more
Old 06-06-2004, 07:16 PM
  #29
D1g1tal V3n0m
I ♥ Acer
Oh I know the Canfields are hardcore heads but figured I'd let him know. They are nice but pricey.
ObSolete just get AFR believe me. They ARE the BEST.
Old 06-07-2004, 04:30 PM
  #30
1hot88drop50
1hot88drop50's Avatar
try www.treperformance.com they have AFR 165's for $1279 i believe! That is by far teh cheapest i have ever seen. check it out, they also have other heads too but I think getting the AFR's for teh price of teh edelbrocks sounds like a good deal to me!!
1hot88drop50 is offline
Quick Reply: What heads would go best with current setup
