17inch cobra rims.. WHAT size tire do i need?
Old 08-12-2006, 02:10 AM
wheelliftnpony
wheelliftnpony's Avatar
Default 17inch cobra rims.. WHAT size tire do i need?
what size tire should i put on my 17'in cobra rims for a 88??? i was thinkn 245 45 17's?
wheelliftnpony is offline
Old 08-12-2006, 02:11 AM
rockett1978
rockett1978's Avatar
Default RE: 17inch cobra rims.. WHAT size tire do i need?
thats whats on mine
rockett1978 is offline
Old 08-12-2006, 02:12 AM
wheelliftnpony
it wont change the gear ratio much will it? cuz its got stock gears and its a 4cyc..
Old 08-12-2006, 03:20 AM
94RoadRacerGT
94RoadRacerGT's Avatar
Thats what I run too, came from ford that way. But wouldnt you having 17s on your 88 already change the ratio?
94RoadRacerGT is offline
Old 08-12-2006, 04:34 AM
crazyhorse
crazyhorse's Avatar
should be about right . how wide is the wheels?
ORIGINAL: wheelliftnpony
crazyhorse is offline
Old 08-12-2006, 09:50 AM
Tumbleweed
Tumbleweed's Avatar
ORIGINAL: 94RoadRacerGT
It will only change the ratio if the diameter of the tire is different than stock, if you keep the tire diameter the same on bigger wheels, you will be fine. Tirerack gives you the tire diameters if you look there to get ideas.
Tumbleweed is offline
Old 08-12-2006, 10:12 AM
TwotoneVert
TwotoneVert's Avatar
I have 235/45 on 17x9 Cobras, and they are an inch wider than the stock wheels I had, and about 1/2 in taller. I used to run a 15x8 with 215/65's. My car is lowered, but they tuck under nice and dont rub at all.
TwotoneVert is offline
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
10-05-2015 06:07 PM
09-03-2015 07:14 PM
AMAlexLazarus
AmericanMuscle.com
09-02-2015 08:59 AM
09-01-2015 08:16 PM
Quick Reply: 17inch cobra rims.. WHAT size tire do i need?
