harmonic balancer question
Old 06-14-2004, 02:39 PM
88stang5.0
88stang5.0's Avatar
Default harmonic balancer question
I went out to races sat night and i had a guy check my timing. he told me that the balancer is 180 Deg off and he didnt know how my car was even running. Now i dont really understand what all he was saying but something about a chunk of the balancer that is cut out is supposed to be somewhere else and it is off 180 deg. So i am wondering if this could be possible and if so how can i fix it. i know when i rebuilt it i put the balancer on the only way it could go on with the key. So again any ideas on what he might be talking about or what not.
Also i was wondering what all affects throttle response becuase when i hit the gas it revs kinda wuick but takes kinda a long time to get to idle again. any ideas on that?
One more question when everyone talks about advancing the timing to 14 deg or whatnot is that 14 deg btdc? or is it 14 deg adv? Say this is the timing marks looking at engine from fron 30.....20....10.....0.....10....20.....30 do i want it about the 14 to the left or 14 to the right? or where should it be? thnx sorry if these are all kinda dumb questions but i am lost in all this stuff. thnx
88stang5.0 is offline
Old 06-14-2004, 09:23 PM
86HOGT
86HOGT's Avatar
Default RE: harmonic balancer question
Sounds like your balancer slipped. Get a new one. The rubber between the two metal portions has let go. When someone says that they advance their timing. It means that the spark is occuring 14 degrees before top dead center. Advanced ~ getting there before.
86HOGT is offline
Old 06-14-2004, 09:36 PM
Mustang88LXKid
Mustang88LXKid's Avatar
ya your gonna need a new one as 86HOGT said, dont want that advanced timing...
Mustang88LXKid is offline
Old 06-14-2004, 10:34 PM
vfast
I ♥ Acer
vfast's Avatar
you need another one asap if it comes off at 5500 rpm hell will be paid
vfast is offline
Old 06-15-2004, 12:06 AM
88stang5.0
88stang5.0's Avatar
Why dont i want that advanced timing? and also how can u tell if the balancer is slipped from looking at it? thnx for the help though
Old 06-15-2004, 01:26 AM
Moosetang
Moosetang's Avatar
Is the balancer a bolt on or does a mechanic have to position it? How are the stock 5.0 harmonic?
Moosetang is offline
Old 06-15-2004, 02:21 AM
sofknez
sofknez's Avatar
I just changed my harmonic balancer in my 94GT. Just need a harmonic balancer puller and a harmonic balancer installer. I was able to rent the tools at auto zone.
sofknez is offline
Old 06-15-2004, 02:22 PM
Moosetang
Moosetang's Avatar
Did you have any sign's it needed replaced or you just playing it safe?
Old 06-15-2004, 11:30 PM
NOS/MAN
I ♥ Acer
NOS/MAN's Avatar
ONCE YOU TAKE IT OFF ,,LOOK AT THE KEY SLOT IT SHOULD BE POINTING STRAIGHT AT 30 DEG.
NOS/MAN is offline
Old 06-16-2004, 12:14 AM
sofknez
sofknez's Avatar
I had a bad vibration in the shifter.
sofknez is offline
Quick Reply: harmonic balancer question
