TWIN TURBO OR SUPERCHARGER???
Old 10-26-2006, 12:22 PM
  #21
7upedition
7upedition's Avatar
Default RE: TWIN TURBO OR SUPERCHARGER???
ummm what he said^!
7upedition is offline
Old 10-26-2006, 12:26 PM
  #22
samseed101
samseed101's Avatar
you're just scared...that's all!
samseed101 is offline
Old 10-26-2006, 12:32 PM
  #23
88BlueGT
88BlueGT's Avatar
dont b scered
88BlueGT is offline
Old 10-26-2006, 12:42 PM
  #24
mpswirl
mpswirl's Avatar
Samseed i didnt say exactly 10hp i said ABOUT 10hp, it varies of course but thats about the ratio between the 2.
mpswirl is offline
Old 10-26-2006, 01:19 PM
  #25
samseed101
samseed101's Avatar
ORIGINAL: mpswirl
A 5.0 w/ trick flow top end kit will yield approximately 285 RWHP. If you add a 10-PSI supercharger you will be pushing approximately 483 RWHP. That's a gain of 198 HP (a 69& gain.) That works out to be 19.8 HP per pound of boost. So you cna round that up and say that it will give you 20 HP per pound of boost...double what you said, and at the level you claimed a turbocharger will give you.
Old 10-26-2006, 01:21 PM
  #26
88BlueGT
88BlueGT's Avatar
Numbers sound a little high to me... I have seen people with track heats, custom grinds and out of the box tw's with 10psi run about 450rwhp. And thats with a custom blower cam too.
88BlueGT is offline
Old 10-26-2006, 01:26 PM
  #27
JBradley500
JBradley500's Avatar
wouldnt a bi-turbo be the best?
JBradley500 is offline
Old 10-26-2006, 01:27 PM
  #28
samseed101
samseed101's Avatar
I used a HP-Boost calculator to get a rough estimate. Were they running any sort of intercooler? I ran teh same exact numbers I used for my results, except I ran it without an intercooler and came up with 449 HP, which is pretty close to the number you listed. (all based on an initial 285 RWHP which is what people seem to get from a good H/C/I upgrade or the TFTW kit.
Old 10-26-2006, 01:29 PM
  #29
88BlueGT
88BlueGT's Avatar
^^^ No intercooler with my numbers... you stand correct!
WTF is a bi-turbo?
88BlueGT is offline
Old 10-26-2006, 01:31 PM
  #30
Black_LX_Coupe
Black_LX_Coupe's Avatar
ORIGINAL: johan166
ORIGINAL: Black_LX_Coupe
I prefer a twin screw or Centrifigal(sp?) because there's no lag.
But eveyone knows turbo's make WAY more power than SC's to deny it is foolish.
I guess it depends on what you're doing with your car....for street....I'd opt for SC. if you're going to the track all the time...I'd go twins with a shot of spray to compensate for the second or so of lag.
technically turbos process high PSI more efficiently... at the 5 PSI range there isn't a big difference
yea well at the 5 PSI range what's the point of having a turbo/SC? might as well just run an octane boost and get the same results.
Black_LX_Coupe is offline
Quick Reply: TWIN TURBO OR SUPERCHARGER???
