TWIN TURBO OR SUPERCHARGER???
Old 10-28-2006, 12:57 PM
  #51
mpswirl
mpswirl's Avatar
Default RE: TWIN TURBO OR SUPERCHARGER???
You can go with a single or twins you wont have hardly any lag.
mpswirl is offline
Old 10-28-2006, 01:04 PM
  #52
FoxGT
FoxGT's Avatar
ORIGINAL: 88blackgt
do some research on the kb for 5.0s a bit. theyre an older design and last i knew theyre non-intercooled. non-intercooled as in kb doesnt even make an intercooler for it, aka fabricate it if you want it. also a 5.0 kb is mostly good for going sideways on the street, unless you've got some good suspension. you want torque a turbo is great for that. go w/ a turbo IMO
also dont bother w/ TTs. single turbo is lighter, cheaper, makes as much if not more power, and is more efficient(due to the aformentioned crossover pipe required for v-style engines). dont worry about torque either, turbos make tooooons of torque. when the turbo is properly sized for the engine there is almost no noticeable lag, especially on a v8. you may not build full boost until 3k, but then again who launches their car at idle? when you launch you are already a ways into your powerband. if you're really worried about not building boost right away, get a 2 step. 4 or 5 lbs of boost right off the line.
twin screws are the 2nd least efficient(the least efficient being a regular Roots), and if you do go to the great lengths required to intercool them, you will still usually not be making that much boost(yes i realize that meth injection can be used as a chemical intercooler, but this can be quite a task for KBs also).
with the turbo, you will have more efficient gains, easily intercooled, lots of torque, and great top end.
That's what their downside is.... not their upside. That's the reason a twin setup has a small efficiency advantage over a single.
ORIGINAL: mpswirl
+1
Either way, I'm sure you'll be happy with the results
FoxGT is offline
Old 10-28-2006, 01:15 PM
  #53
OneFine89Mustang
OneFine89Mustang's Avatar
twin turbo no doubt
OneFine89Mustang is offline
Old 10-28-2006, 02:34 PM
  #54
88blackgt
88blackgt's Avatar
ORIGINAL: FoxGT
ORIGINAL: 88blackgt
ORIGINAL: mpswirl
+1
i was saying that single turbos are more efficient than TT. i said its MORE efficient but didnt say than what. single turbo doesnt require a crossover pipe.
88blackgt is offline
GimpyHSHS
19
12-19-2023 01:12 PM
TCStangerv6
10-11-2015 05:57 PM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: TWIN TURBO OR SUPERCHARGER???
