What the heck is this?
Old 10-26-2006, 04:19 PM
gspfunk
gspfunk's Avatar
Default RE: What the heck is this?
x2 on EGR valve. The hose will run to a cluster of 4-5 hoses on the pass. side between the firewall and strut tower. If all your emissions stuff is hooked up, you should have:
2 lines running to 2 different solenoids on the hose between the smog pump (if you still have it) and the H pipe.
1 line running to the EGR (obviously not there or not hooked up on that end)
1 line running to the vacuum tree on the underside of your upper intake manifold (at the back)
gspfunk is offline
Old 10-26-2006, 04:24 PM
samseed101
samseed101's Avatar
I'm thinknig the previous owner probably did a half-assed smog delete and egr delete or something. Then again, he did mention having idoe problems so maybe there really is a vacuum line thats off somewhere. Of course, you'd be able to hear that.
samseed101 is offline
Old 10-26-2006, 05:03 PM
iamvillani
iamvillani's Avatar
I'll check it out when i get home, thanks for all the input
iamvillani is offline
Old 10-27-2006, 01:56 PM
iamvillani
iamvillani's Avatar
ok, so it looks like the smog pump is gone. there is a band clamp that is on the firewall on passanger side. that looks like it used to hold it. There is a open black small hose comeing out of the firewall int he passanger side corner. I taped up the open end of the egr valve shoudl i have done this. Thanks.
Old 10-27-2006, 02:17 PM
gspfunk
gspfunk's Avatar
Get another pic or 2 of what you're talking about. It's alot easier to help you that way and advice will be more accurate if we know exactly what you're talking about......
gspfunk is offline
bryan616fl
01-25-2019 09:07 PM
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
showoffzx2
4 Cylinder NA and Turbo
09-14-2015 08:40 PM
MustangJourney
09-02-2015 04:32 PM
BlackMage
04-07-2005 08:28 PM
Quick Reply: What the heck is this?
