egr
RE: egr
do you mean you dont have to have emissions by law or you've already removed the smog pump/egr system? The only disadvantage to EGR removal is you may see a small decrease in fuel mileage...
RE: egr
if i make a plate that blocks it off and leave it unhooked will my car run any different. what i mean is will run better or worse with out this hooked up. cause in minnesota we dont have emmissions test and i have already taken off my air pump and i dont have cats so is the egr is basically not doing anything for my car right now.
RE: egr
You wont go faster if you take it off and then you will have to mess with getting the CEL to stay off. I would just leave it alone, but you can take it off. You may have a little detonation cus you cumbustion chambers will burn hotter(that is what the EGR does, cool the burn so you create less NOX gasses.) Do a google on it and go from there. I took mine off.
ShaneB26154
35
03-04-2021 04:05 AM
TfcCDR
09-14-2015 12:08 PM
