no start no spark...more info
Old 10-28-2006, 03:54 PM
Idrum88
Idrum88's Avatar
Default RE: no start no spark...more info
how do i find a bad wire
Idrum88 is offline
Old 10-28-2006, 04:04 PM
Idrum88
Idrum88's Avatar
ORIGINAL: fourfivefour
ORIGINAL: samseed101
ORIGINAL: aode06
classic symptoms of a failed PIP in the dizzy. get a used dizzy.
He already replaced the dizzy. Also said that he replaced the ICM. Every time I have seen this in the past, it has either been the PIP, coil, or ignition control module. I mean...there are only so many parts involved in creating a spark...
That is correct many things contribute to making spark. Don't forget the crank sensor.
I have the whole test procedure in front of me and it is very extensive. (too much to type)
With all the parts you have replaced you could have paid to have it fixed. You can replace every part in the system but if it is a wiring problem it still wont run.
my manual says there is no crank sensor ina 5.0
Idrum88 is offline
Old 10-28-2006, 04:08 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Idrum88
the car does not start....i got gas in the rails.....but i have no spark...engine rolls over but no fire....im getting 12 volts to the coil but there is nothing coming out of the coil no spark to the dist......i have replaced the distributor...the coil...and the ignition switch......does anyone know if there is supposed to be any volts goin through the tan wire to the coil.....any help would be greatly appreciated
Noit sure of the wire color, but there should be voltage to the coil. If not, that's a place to start
PRO50SC is offline
Old 10-28-2006, 04:09 PM
fourfivefour
fourfivefour's Avatar
ORIGINAL: Idrum88
ORIGINAL: aode06
I thought it was 3.8. Did you just change your sig line? Or I miss read it.
If it is a 5.0 what year?
fourfivefour is offline
Old 10-28-2006, 04:10 PM
Idrum88
Idrum88's Avatar
ORIGINAL: PRO50SC
ORIGINAL: Idrum88
i have 12 volts in the one side of the plug but the other side is the tan wire and it has like .5 volts
Idrum88 is offline
Old 10-28-2006, 04:11 PM
Idrum88
Idrum88's Avatar
ORIGINAL: Idrum88
ORIGINAL: aode06
its a 94
Idrum88 is offline
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: Idrum88
ORIGINAL: PRO50SC
ORIGINAL: Idrum88
Have you checked the voltage on the other side while cranking it?
PRO50SC is offline
Old 10-28-2006, 04:13 PM
Idrum88
Idrum88's Avatar
ORIGINAL: PRO50SC
ORIGINAL: Idrum88
ORIGINAL: PRO50SC
ORIGINAL: Idrum88
no i have not what should it read out??
Idrum88 is offline
Old 10-28-2006, 04:17 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
I think like at least 9 or 10 volts if I remember correctly. Don't hold me to it though. Been along time since I had to diagnose one w/o a manual.
PRO50SC is offline
Old 10-28-2006, 04:19 PM
Idrum88
Idrum88's Avatar
ORIGINAL: PRO50SC
ill go check....and it should only read that while cranking right??
Idrum88 is offline
Quick Reply: no start no spark...more info
