autometer help
Old 11-06-2006, 08:25 PM
scooterstang
scooterstang's Avatar
Default autometer help
can someone try to help me out with an autometer install. i've got electronic half sweep gauges from autometer. I have oil temp and oil pressure. can someone just kinda guide me through what i need to do? thanks
scooterstang is offline
Old 11-06-2006, 09:03 PM
TwotoneVert
TwotoneVert's Avatar
Default RE: autometer help
You will need to connect to a switched power, and ground. Each gauge will have another power and ground for lighting, and you will need to install the sending unit wiring. Dont use factory, at least mine were not good enough to use. I recommend you find the adapter that goes in place of the oil filter, and the filter screws into that. You can connect oil temp there. I think you can connect oil pressure as well, I need to find that part number again. I need one too for the oil temp. Make sure you have a good ground, or you will get false readings, I had to learn the hard way!
TwotoneVert is offline
Old 11-07-2006, 12:52 AM
scooterstang
bump
Old 11-07-2006, 12:56 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: scooterstang
bump
http://hp.autometer.com/instruction_..._download.html
PRO50SC is offline
Old 11-07-2006, 01:03 AM
LCBlackDep183
LCBlackDep183's Avatar
^I do belive pro pwned you
LCBlackDep183 is offline
fvittes
01-01-2005 08:51 PM
fvittes
12-08-2004 05:53 AM
BLU BLZ 03SNAKE
11-12-2004 02:34 PM
nnhockey18
09-13-2004 07:06 PM
Moosetang
08-23-2004 01:04 PM
Quick Reply: autometer help
