gt40-p heads
Old 11-12-2006, 10:09 PM
slowlx
slowlx's Avatar
Default gt40-p heads
hey, i am new to the mustang
but i bought a 88 lx that has a set of the gt40-p heads, what i need to know is i got a set of flow tech long tube headers for it
and the spark plugs will not go in for the header
is there a set of long tubes that will work and how much modifaction does it take to make them work if there is some.
i am sorry if i posted this in the wrong section but any help will be great thanks.
slowlx is offline
Old 11-12-2006, 10:12 PM
ckyguy68
ckyguy68's Avatar
Default RE: gt40-p heads
You have to get special headers made for the GT40Ps because of the different plug location.
ckyguy68 is offline
Old 11-12-2006, 10:13 PM
Ninety5five0
Ninety5five0's Avatar
Dont think there are long tubes that will work without modification. There are a specific gt40P header made for those heads. The closest fitting longetube, i think, is the bbk LT's, but i think they still need to be modified a bit. Good luck, but id stick with shorites unless your over 500 HP, and theres prolly no way with P heads, unless your blown a huge amount.
Ninety5five0 is offline
Old 11-12-2006, 10:15 PM
BlackLX
BlackLX's Avatar
Shorty's
http://www.latemodelrestoration.com/...0%201&comp=LRS
Couldn't find any long tubes
BlackLX is offline
Old 11-12-2006, 10:22 PM
Ninety5five0
ORIGINAL: BlackLX
Shorty's
I got mine on ebay, MAC jethot coated for 180 shipped, brandnew.
Old 11-12-2006, 10:24 PM
Mowin8603
Mowin8603's Avatar
ORIGINAL: Ninety5five0
ORIGINAL: BlackLX
Shorty's
not bad! i think ill be using ebay as much as possible for mods, but its still a little nerve racking buying from ebay to me..
EDIT: just found these on ebay
http://cgi.ebay.com/ebaymotors/FORD-...QQcmdZViewItem
Mowin8603 is offline
Old 11-13-2006, 09:17 PM
slowlx
slowlx's Avatar
thanks for the help,is there a deferints in between the gt40 heads and the gt40p heads,
becouse i found a set of hooker long tubes for the gt40 heads.
or what kinda of mods i need to do to fit the bbks
thanks again for the help
slowlx is offline
Old 11-13-2006, 09:21 PM
Ninety5five0
The P and the 40s are different. The P's have a different plug angle, its almos strait out, instead of in at an angle. They also make different compression, and overall the P's outflow the 40's.
http://www.stangpro.com/html/article...les/gt40p1.htm
Old 11-13-2006, 10:03 PM
slowlx
slowlx's Avatar
thanks,mine are just about strait out, i bought this car with the stuff already on its got a pretty good size cam just not for sure what kind.
when i had the heads off the pistons looked real good had hardly any carbon on them, they where 4 valve relife i dont really know what came stock in it.
what kind of injecters can i put in it, i belive one is stickin it has a 70 or 75 mass air but i have heard people sy that the mass air has to be tuned for the injectors
thanks
slowlx is offline
Old 11-13-2006, 10:06 PM
Ninety5five0
What color injectors are in it ? 24#ers wouldnt hurt, but might not be necessary. Those are prolly stock pistons, i believe the stock pistons have 4 notches in them, not positive tho....
And yes, you have to get a different MAF to match the injectors. Stock is 19#ers, so if you want to upgrade to 24#ers you'd need a different maf calibrated for 24#ers.
Quick Reply: gt40-p heads
