How to fix code 332 EGR flow insufficient?
After I installed my 331, I keep getting this code 332 EGR valve flow/opening insufficient. The tube from the EGR is hooked up to a different cyclinder now with the longtubes but would that make the light go on. It comes on after a minute or two of driving. The car runs fine. I just want the light to go out. Does anyone have any suggestions?
RE: How to fix code 332 EGR flow insufficient?
In your case (SN95 with EGR Valve Position sensor) code 332 = EGR valve opening not detected....no voltage change in the EVP sensor. You could either check the vacuum lines that feed the EGR Valve Regulator (EVR) solenoid (vacuum all the time) and the one from the EVR to the EGR valve (broken, plugged, routed incorrectly,.....)...or, make up a resistors triangle as shown below and not have the CEL turn on and delete the EGR function (as it is now)....
I called my the guy that tuned it and he said to send him the chip and he'll tunr off all of the EGR codes. He though he took care of it when he tuned it but obviously not. Thanx for the help.
trashxtrash
09-20-2015 10:49 PM
TfcCDR
09-14-2015 12:08 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
zanemoseley
09-06-2015 12:58 PM
