wtf!!!!!!!!!!!!
Old 12-07-2006, 12:44 AM
95gt302
95gt302's Avatar
Default wtf!!!!!!!!!!!!
so i was with my girl friend tonight and the pony just dies then i couldnt start her back up. i just heard my fuel pump just running i tried to start it and all i got was it sounded like i wasnt getting fuel after five minutes i got it started but i wanna know what this is
95gt302 is offline
Old 12-07-2006, 12:47 AM
5.0stanger
5.0stanger's Avatar
Default RE: wtf!!!!!!!!!!!!
Maybe a ignition modual...they get hot and quit working, then they cool and start working again.
5.0stanger is offline
g2_5point0
g2_5point0's Avatar
ignition module? when my heats up, my car will die out and wont start or run properly til it's cooled
g2_5point0 is offline
Old 12-07-2006, 12:54 AM
mattdel
mattdel's Avatar
TFI or coil, both will act up hot.
mattdel is offline
Old 12-07-2006, 12:57 AM
5.0stanger
5.0stanger's Avatar
The ignition modual(that is what I call it, also what it is called at the parts store) is mounted on the dizzy and will do what you discribe..a bad coil will also do that too, but seeing that you have a MSD, I would guess the modual.
Old 12-07-2006, 01:20 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
yeah the tfi(ignition module) is probably bad
rmodel65 is offline
Old 12-07-2006, 02:04 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: 5.0stanger
Incorrect on the location... its actually mounted on the passengerside fender well... his car is a 95.. so look under your air intake, itll be mounted over there!
AdderMk2 is offline
Old 12-07-2006, 02:11 AM
FiveLiterRiceEater
FiveLiterRiceEater's Avatar
i also found in a few cases the power wire going to this module would become open when it got hot and do the same thing. that was only like twice though, its usually just the tfi module or ignition module. and like mattdel said, a coil sometimes.
FiveLiterRiceEater is offline
Old 12-07-2006, 08:53 AM
Stanpower
Stanpower's Avatar
http://www.aa1car.com/library/2003/us80312.htm
Stanpower is offline
Old 12-07-2006, 12:57 PM
95gt302
95gt302's Avatar
not sure if it means anything but at an idel my battery guage goes down alot almost to the red and my headlights get dim along with all the lights inside the car
95gt302 is offline
Quick Reply: wtf!!!!!!!!!!!!
