my stangs got the shakes
Old 07-23-2003, 03:10 PM
spike306
spike306's Avatar
Default my stangs got the shakes
hey fellas,
i've got an '89 gt 5.0 with about 417 rwhp, and the last couple of days i've got a wicked vibration throughout the car. it's mainly at idle. i checked the motor mounts, and the tailshaft mount, and all of those are fine. so now i'm kinda stumped. anybody got any ideas?
spike306 is offline
Old 07-23-2003, 03:18 PM
WhiteHawk
WhiteHawk's Avatar
spike, shakes......are we talking stangs or heroin here?? </P>
(sorry, couldn't resist)</P>
<IMG src=smileys/smiley1.gif border="0"></P>
WhiteHawk is offline
Old 07-23-2003, 03:21 PM
spike306
spike306's Avatar
no prob. stang of course. i'm just confused
spike306 is offline
Old 07-23-2003, 10:02 PM
BLOWN91VERT
BLOWN91VERT's Avatar
Spike306, are you still running the stock clutch fan? I have a buddy that had his go out and caused a nasty vibration. Changed it and all the problems went away. Just and idea to check.
BLOWN91VERT is offline
Old 07-23-2003, 11:47 PM
spike306
spike306's Avatar
i haven't checked that yet, but thanks for the tip. i'll let you know how it goes
spike306 is offline
Old 07-24-2003, 10:31 PM
makarovboy
makarovboy's Avatar
Spike, check your harmonic damper. They've been known to come apart.
makarovboy is offline
Old 07-26-2003, 12:22 AM
dogg5.0
dogg5.0's Avatar
Have you checked the oil? LOL
dogg5.0 is offline
Old 08-04-2003, 11:58 AM
Tangerine GT
Tangerine GT's Avatar
My motor mouns looked perfectly fine on my old engine. When I took it out to swap in the stroker they pretty much broke in half... they looked fine though. What kind of mounts are on there? If you're still running stock ones you should look into the energy suspenspension polyurethene ones. I think you can get all 3 mounts for $110 from Summit. Check your balancer too. Is it only at idle? I have a friend who was getting vibrations from an exhaust leak on that connecting pipe between the 2 heads in a 95 5.0. Make sure you don't have any exhaust leaks also.
Tangerine GT is offline
Old 08-07-2003, 05:06 PM
stang574
stang574's Avatar
Usually when the harmonic damper go bad the vibration gets worse as the rpms increase. But its woth a check. If it only happens at idle it can only be a few things; flywheel, dampener, fan, or an internal unbalance in the reciprocating assembly.
stang574 is offline
Old 08-07-2003, 05:11 PM
BCisme
BCisme's Avatar
stang574.... you mean vibration damper.... harmonic balancer is the nickname for it.<IMG src=smileys/smiley2.gif border="0">it mounts on the end of your crankshaft, and helps minimize the vibration cause by the irregular motion of the crankshaft. </P>
</P>
this has been another two minute tech tip with BCisme. <IMG src=smileys/smiley4.gif border="0"></P>
BCisme is offline
Quick Reply: my stangs got the shakes
