buying a 90 5.0
Old 07-23-2003, 04:13 PM
90 stang
90 stang's Avatar
Default buying a 90 5.0
i am buying a 90 5.0 gt i wanted to ask experianced mustang guys how hard is it to get 450hp out of the motor all motor?,it comes with an extra block and gt40 heads
90 stang is offline
Old 07-23-2003, 04:49 PM
spike306
spike306's Avatar
it will take a bit of time and money!!! i've got 417 in the rear wheels, but there's quit a bit on it. it's bored 40 over with ported and polished windsor jr. stage 3 heads that match the port and pollished edlbrock rpm upper and lower intake.
high compression trw forged pistons
steel forged crank
eagle conecting rods
e303 cam
1.7 cobra roller rockers
roller lifters
comp pushrods
73mm maf
70mm throttle body
24 lbs injectors
190 lph pump
adjustable fuel pressure regulator
centerforce 30lbs flywheel
king cobra clutch
bbk fendr mount cold air intake
msd 6al ignition
ceramic coated equal lenth headers
bassani x pipe
2 chamber flows
and about7 grand in the suspension
spike306 is offline
Old 07-23-2003, 04:52 PM
Sean
Sean's Avatar
Sounds like a beast Spike.<edited><editID>Sean</editID><editDate>37825.6197800926</editDate></edited>
Sean is offline
Old 07-23-2003, 04:55 PM
WhiteHawk
WhiteHawk's Avatar
Not too hard, nice heads, nice intake, CAI, Headers/mufflers, nice complete ignition system, some ppl say underdrive pulleys - although I didn't note a difference, that should bring your car close to 400 <U>IF</U> the engine is running properly and is nice and tight......Maybe 400....after that, it's just a matter of good combo, better injectors etc... </P>
Naturally aspirated...</P>
WhiteHawk is offline
Old 07-23-2003, 05:00 PM
WhiteHawk
WhiteHawk's Avatar
7K in the suspension???? damn dude (spike), what can you possible have under there suspension=wise for that kind of money ???? Even the Griggs GR-40 PRO system which is the premium is not more than 6K... -- I'm not questioning you, but I'm really curious.</P>
Old 07-23-2003, 05:10 PM
90 stang
90 stang's Avatar
well it comes with an extra block i wanted to take it to an 306,it already has msd ported upper and lower intake manifold,csa,headers,exaust worldclass t-5 tranny,and 373 gears so it wont be too bad on the $$$ it already has alot of the parts
90 stang is offline
Old 07-23-2003, 05:38 PM
WhiteHawk
WhiteHawk's Avatar
take it to 306....you'll get there with all the other stuff.
Old 07-23-2003, 07:25 PM
spike306
spike306's Avatar
i wouldn't cross out the idea of stroking it either
spike306 is offline
Old 07-23-2003, 10:04 PM
90 stang
90 stang's Avatar
ztroking seems kinda pricey
90 stang is offline
mustang0291
10-12-2015 07:55 AM
Matt's 95 Stang
10-05-2015 07:16 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
09-25-2015 06:30 PM
Quick Reply: buying a 90 5.0
