confused about my 1/4 mile time
Old 02-08-2007, 01:20 AM
  #21
93 LX FiveO
93 LX FiveO's Avatar
Default RE: confused about my 1/4 mile time
the gear ratio is bogging the car.. nothin u can do
i have 3.27's and its still slow as hell in 1st
aluminum driveshaft also reduces the rotational mass required to turn it, making the car accelerate faster.
93 LX FiveO is offline
  #22
Ninety5five0
Ninety5five0's Avatar
Get those gears in then take it back. I'd get some sticky tires too. Also if you can, check your timing, i'd bump it up as high as possible, should be around 14*.
Ninety5five0 is offline
Old 02-08-2007, 01:21 AM
  #23
Stevens91gt
Stevens91gt's Avatar
haha well thanks guys
so you dont think it's anything to do with the comp?
im just making sure so i can rule that out
cuz my brother and his friends think it might be that..but idk
ya i was gonna order a shift kit and get a new filter
and change all of that soon
Stevens91gt is offline
Old 02-08-2007, 01:24 AM
  #24
93 LX FiveO
91 uses an A9P for auto's.. the best CPU for ur car.
Old 02-08-2007, 01:31 AM
  #25
Stevens91gt
well my brother just told me
that when i go down this weekend
he'll buy me the fluid and filter
and we're gonna change that stuff
and then check the timing and put it to 14*
thanks for all your input guys
hopefully next time i go i do way better
Old 02-08-2007, 01:33 AM
  #26
shaners90lxhatch
shaners90lxhatch's Avatar
Short of using a gauge, there is no way to judge compression. MASSIVE crankcase pressure perhaps, but you should have noticed something like that. SPOUT is a wire that allows the cars computer to control spark advance. Without it your car isa pooch. If this wire opens up (very easily possible) you will haveclose to a 17 second 1320.
shaners90lxhatch is offline
Old 02-08-2007, 01:35 AM
  #27
92hatchLX
92hatchLX's Avatar
You have other issues with your car dude. At 6000 ft. elevation and 92 degrees farenheit, I ran a 15.5 @ 91.25 mph and a 2.3 60 ft. Only mods that I had were gears, intake, headers and a few little bolt ons. Something is really wrong there, even though it's an AOD and you're not at sea level, you should not be running that slow. Run codes and do some diagnostics before you start throwing money into a torque converter and other performance mods. Have you cleaned your MAF, air filter, checked plugs, or anything like that?
92hatchLX is offline
Old 02-08-2007, 01:36 AM
  #28
Stevens91gt
ohh arite..where is the wire located?
like can you show a pic of an engine bay
or describe where it is?
sorry, but im curious as to know what it is
Old 02-08-2007, 01:40 AM
  #29
Stevens91gt
ORIGINAL: 92hatchLX
no i havnt run codes or done diagnostics..ill try that
what's the best way to do that?
i havnt cleaned my MAF, air filter, didnt check the plugs
i guess ill be working on it on saturday
Old 02-08-2007, 01:43 AM
  #30
frdmstng1986GT
frdmstng1986GT's Avatar
ORIGINAL: Stevens91gt
ORIGINAL: 92hatchLX
also, just a side note. if you bump the timming better plan on running mid grade in it just to be on the safe side.. some guys get away with running regular.. and some guys have to run premium when they go to 14*
frdmstng1986GT is offline
Quick Reply: confused about my 1/4 mile time
