tach question
Old 02-10-2007, 01:27 AM
tmajikman
tmajikman's Avatar
Default tach question
Just got my 87 gt, the tach sits at normal position when the car is off, when I start it, the tach goes backwards and stays pegged at 7000 rpms, can the tach be wired backwards, is this a sign that the tach is just no good, and lastly, are the leads for the tach on the coil, two small wires and can they be tested or reversed to see if it fixes it. Sorry for the long post.
tmajikman is offline
Old 02-10-2007, 01:32 AM
AdderMk2
Banned
AdderMk2's Avatar
Default RE: tach question
are we talking about a stock tach, or an aftermarket one?
AdderMk2 is offline
Old 02-10-2007, 01:34 AM
tmajikman
tmajikman's Avatar
sorry, stock tach, I plan on getting an aftermarket tach, but until that time I want to get this one working or at least figure out if it is able to be fixed.
Old 02-10-2007, 01:39 AM
AdderMk2
Banned
AdderMk2's Avatar
you may need to take the instruments apart, it sounds to me like your needle is on the wrong side of the stopper...
although it is possible that your cluster is just screwed
AdderMk2 is offline
Old 02-10-2007, 01:45 AM
tmajikman
tmajikman's Avatar
o.k I will do that adder,thanks again,can you buy just the plastic piece that goes over the cluster.
Old 02-10-2007, 01:54 AM
AdderMk2
Banned
AdderMk2's Avatar
If you find out that your cluster is bad.. it might not be a bad idea to try to find a SSP or Cobra cluster
AdderMk2 is offline
Old 02-10-2007, 02:07 AM
tmajikman
tmajikman's Avatar
so if the tach is bad, then the whole cluster has to be changed out, is that correct?
Old 02-10-2007, 02:15 AM
mattdel
mattdel's Avatar
doesnt sound like the tach is bad to me, if the needle is moving backwards, the signal wire for the tach is being grounded out.
mattdel is offline
Old 02-10-2007, 02:17 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: mattdel
which could be something IN the tach... thats why I said "IF"
AdderMk2 is offline
Old 02-10-2007, 10:32 AM
tmajikman
tmajikman's Avatar
the two leads for the tach are on the coil right, is there a way to test that with a muti meter?
Dokilar
15
10-16-2015 08:13 PM
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
Quick Reply: tach question
