Front brake rotors
Old 02-16-2007, 10:50 PM
tom50
tom50's Avatar
Default Front brake rotors
How much better are drilled and slotted rotors over stock? I think stock are like $45 and d/s $110. Info please?
tom50 is offline
Old 02-16-2007, 10:54 PM
89 fox
89 fox's Avatar
Default RE: Front brake rotors
i just installed mine and felt a pretty good difference...well worth the $$$$...plus they look good!!!
89 fox is offline
Old 02-16-2007, 10:58 PM
tom50
tom50's Avatar
What brand did you get? how much
tom50 is offline
Old 02-16-2007, 11:00 PM
89 fox
89 fox's Avatar
i have baer decelerotors....i paid 200 a pair
89 fox is offline
Old 02-16-2007, 11:40 PM
Maxwelhse
Maxwelhse's Avatar
I've got summit cross-drilled (non-slotted) on my car and I think they were like $55/ea (on clearance at the time).
I went cheap because I know I want to 5 lug it later. Those and ceramic pads / clean and lube fron and rear made a huge difference.
Maxwelhse is offline
Old 02-17-2007, 12:21 AM
yellow93lx
yellow93lx's Avatar
I have read the drilled is over kill if you are not road racing and that they will crack in the drilled holes after a while. The other thing said is they are high heat roters, so with just normal stopping you do not get them up to the proper temp to work good. Has anyone had that problem or is it just the companys that do not make the drilled rotors puting down their competitor?
yellow93lx is offline
Old 02-17-2007, 01:18 AM
89 fox
89 fox's Avatar
the only time i have heard of them cracking between the holes is under VERY extreme conditions....i know i felt a really big difference in stopping distance when i put mine on...
89 fox is offline
SSRFUZZY
Members Other Vehicles
01-06-2016 08:22 PM
10-07-2015 07:02 PM
PB Pod
Forum Issues and Feedback
09-17-2015 08:32 PM
09-16-2015 07:53 PM
Quick Reply: Front brake rotors
