1992..AOD....not engaging
Old 02-17-2007, 04:46 PM
bobs92
bobs92's Avatar
Default 1992..AOD....not engaging
I have a 1992 GT 5.0....On my last long drive the OD would not engage ....at about 40 to 45 miles an hour the engine would freespin....it is OK in drive.....is this the OD band or is there anyother sensor switches involved that might cause this problem....it has only 41,000 miles. If it is the OD band...is it safe to use only in the drive mode.....thanks....
bobs92 is offline
Old 02-17-2007, 04:54 PM
90Lxstanger
90Lxstanger's Avatar
Default RE: 1992..AOD....not engaging
Is the throttle vavle linkage undone(or came undone) happened im my brother Grand Marquis,it did the EXACT same thing,smoked out the OD band, check that first(cant tell you exactly where it is, cuz i dont own a AOD car), but if you have a manual then you in luck or someone on here will know porbably. If yiu do drive it leave it in DRIVE, but i wouldnt leave the driveway, personally.
90Lxstanger is offline
Old 02-17-2007, 05:04 PM
88stang5.0GT
88stang5.0GT's Avatar
if its an aod check the throttle body shift cable gromit on the bottom of the throttle body because mine was broken and it did something similiar and dont drive it it i fried two trannies because it was messed up and i drove it
88stang5.0GT is offline
Old 02-17-2007, 05:07 PM
90Lxstanger
Yeah i think thats the TV linkage really, not positive, but it might be...........
Thunderball
15
11-22-2015 11:49 PM
AmericanMuscle4.6GT
11-10-2015 02:06 PM
guitarman376
09-30-2015 05:54 PM
Pyrate Dave
09-10-2015 07:30 PM
Quick Reply: 1992..AOD....not engaging
