where should i jack
RE: where should i jack
That wont crush the gasket will it? When I did my headers (I was on a lift) I lowered the car down onto this tall jack type deal (I forgot what it was called) and i used the balancer. When I did exhaust work in my garage I used a block of wood under the oil pan deal and I think thats what caused it to leak.
i would rather support the engine by a piece of wood on the oil pan then the balencer. your not going to hurt the pan or gasket, the wood distributes the weight over a larger area, not the crank snout[:@]
ORIGINAL: turbosha
ORIGINAL: redmustang83596
ORIGINAL: BackInBlack90LX
thanks you pro ill see what happens im in the dark so i hope everything goes smooth
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
09-17-2015 07:57 PM
