cleaning fuel injectors
Old 02-20-2007, 05:00 PM
stangman94
stangman94's Avatar
Default cleaning fuel injectors
I have my fuel injectors out and they are dirty. Is there any way to safely clean them?
stangman94 is offline
Old 02-20-2007, 05:04 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
Default RE: cleaning fuel injectors
not really...you can send them off to be cleaned and flowed..this place does great work
http://www.witchhunter.com/injectorserv1.php4
2 kwik is offline
mypony89
mypony89's Avatar
Take a # 10 screw and take out the filter, get some injector cleaner from any auto store and soak it in there then after its been soaked take and blow it dry. I used an air compressor. Hope it helps.
mypony89 is offline
Old 02-20-2007, 05:21 PM
samseed101
samseed101's Avatar
You know... someone should create a sticky section here and put a bunch of useful info like this in a sticky. Although I guess it would get crowded with so many stickies. Maybe it would bea easier to make a single sticky post and call it "Tech Articles" and in that post, there can be numerous useful links...
just a suggestion.
samseed101 is offline
samseed101
samseed101's Avatar
http://fordfuelinjection.com/index.php?p=82
Old 02-20-2007, 05:31 PM
94gtcoupe
94gtcoupe's Avatar
i agree sam, there should be a sticky with usefull info on how to clean misc. parts like this and other usefull info along with it
94gtcoupe is offline
Old 02-20-2007, 05:50 PM
FoxGT
FoxGT's Avatar
Good info!
Could have went in the junkyard / DIY 2 sticky if it hadn't got taken down
FoxGT is offline
Old 02-23-2007, 12:19 PM
mypony89
mypony89's Avatar
There is a sticky on how to do that. Its were I got my info. Its called Tech Articles by HC_Crazyhorse.
https://mustangforums.com/m_2141191/tm.htm
mypony89 is offline
EZFEED
05-05-2016 08:54 PM
pimp2303
09-17-2015 08:45 PM
SteelerNation82
09-16-2015 07:11 AM
TfcCDR
09-14-2015 12:08 PM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: cleaning fuel injectors
