Your opinion on my mods?????
Old 02-21-2007, 08:30 PM
only90s
only90s's Avatar
Default Your opinion on my mods?????
The following is a list of parts I have bought/installed this winter....I am tired of all the work but also excited about if finally running.
308 FORGED SHORT BLOCK
TWISTED WEDGE HEADS
COMETIC MLS HEAD GASKETS
TRICK FLOW STAGE 1 CAM
TRICK FLOW ROLLER ROCKERS
TRICK FLOW MAIN GIRDLE
HOLLEY SYSTEMAX INTAKE
75MM THROTTLE BODY
76MM MASS AIR
42LB INJECTORS
AEROMOTIVE FUEL REGULATOR
VORTECH SQ TRIM 10LBS
POWER PIPE
MSD 6AL
MSD COIL
-T REX FUEL PUMP
-255 IN TAKE FUEL PUMP
REBUILT DISTRIBUTOR
NEW CLUTCH FAN/RADIATOR
AC ELIMINATOR
93 COBRA WATER PUMP PULLEY
NEW WATER PUMP
NEW HARMONIC BALANCER
NEW FLYWHEEL
NEW CENTERFORCE DUAL FRICTION CLUTCH
3.73 GEARS WITH MAC REAR END GIRDLE
-SCT Eliminator Chip-5 programs
STEEDA SPORT SPRINGS
NEW STRUTS/SHOCKS
UPPER AND LOWER REAR CONTROL ARMS
STEERING SHAFT AND SUBFRAME CONNECTORS FROM MAXIMUM MOTORSPORTS
NEW 93 COBRA FRONT BUMPER
NEW HARWOOD 3 INCH COWL HOOD
NEW WINDOW AND DOOR MOLDINGS
NEW DOOR HANDLES
FUEL PRESSURE GAUGE-EXTERNAL ON COWL
Hope to have running in a month or so and then hit the dyno by early May for proper tuning...
only90s is offline
Old 02-21-2007, 08:36 PM
94ford5liter
94ford5liter's Avatar
Default RE: Your opinion on my mods?????
sounds like one hell of a ride. Good luck with that man, im sure it is going to go like a bat out of hell.
94ford5liter is offline
Old 02-21-2007, 08:40 PM
90mustang5.8
I ♥ Acer
90mustang5.8's Avatar
that will be sweet.
90mustang5.8 is offline
Old 02-21-2007, 08:42 PM
only90s
only90s's Avatar
Ya we will see....not a daily driver of course....trying to make a somewhat reliable street car out of it.....going to add Methanol Injection this spring if I dont see at least 450 to the wheels when it hits the dyno.
only90s is offline
Old 02-21-2007, 08:55 PM
immr.mustang
immr.mustang's Avatar
Have fox lake port those heads, call afm for a blower cam(or fox lake) and you will have no problem with that.....more like 500 with a little more boost and a great tune. The power pipe, if it is an AFM should get you like 2-3 more psi I've read....
immr.mustang is offline
Old 02-21-2007, 09:06 PM
burning the tiers
burning the tiers's Avatar
nice cant wait to hear about how it runs it should make atleast 475 hp
burning the tiers is offline
Old 02-21-2007, 09:45 PM
redRPMhatch
redRPMhatch's Avatar
I would have gone with a diff. cam.
redRPMhatch is offline
Old 02-21-2007, 10:24 PM
nmerrill
nmerrill's Avatar
Why the SQ trim? You should be making alot of power! Nice setup!
nmerrill is offline
Dokilar
15
10-16-2015 08:13 PM
UrS4
10-03-2015 06:23 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 10:29 AM
TimeLord101
10-01-2015 06:40 AM
Quick Reply: Your opinion on my mods?????
