Question... rivets
Old 02-21-2007, 11:36 PM
niseyd07
niseyd07's Avatar
Default Question... rivets
Ok i kno some of ya get tired of the same ol ?s over n over......n i try to search it but nothin in detail came up on removing rivets, it just says drill em out, but does it matter what size drill bit? any s[pecial way, what excalydo i do.Everyone seems to make replacing door handles a simple job so i figure i could jus do it myself. I also saw that some ppl siad its easier to use bolts, i want to do that since i dnt have a rivet gun, but what size kind of bolts? At first i jus thought id take it to a bodyshop and have em installed n some guy told me 65 EACH door, lol i said no its ok. Stupid people jus tryin to make easy money cuz they saw that im a girl. Anyways if anyone could be nice enough n help out?
niseyd07 is offline
Old 02-21-2007, 11:54 PM
stang8689
stang8689's Avatar
Default RE: Question... rivets
The rivets are 1/4" aluminum. First its best to use a punch and hammer and punch out the center stud. Then take a 1/4" drill bit and drill through it. You might have to move the drill around in a little circle toward the end to reem the hole out. you can get the Big daddy rivet guns really cheap these days. search the internet or Ebay probably like $15. You can also use it to change door glasses, regulators and window motors and doo lock actuaters.
stang8689 is offline
Old 02-22-2007, 12:24 AM
vristang
vristang's Avatar
Be sure to buy the ALL metal replacement handles. They will last forever...
Replacing the rivets isn't worth the time.
Here is a thread on another board that discussed using carriage bolts.
http://forums.stangnet.com/showthread.php?t=676081
Basically, you find some 1/4" carriage bolts (rounded pan head with no screw driver slots) and file the holes in the new door handles to accept the square shank of the carriage bolt.
A little thread locker, or even better nylok nuts, and the bolts will never loosen.
Take the time to spray paint the heads of the carriage bolts, and it willlook better than factory.
jason
vristang is offline
Old 02-22-2007, 12:33 AM
primetime5.0
primetime5.0's Avatar
ORIGINAL: vristang
jason
I broke a metal handle, so they really dont last forever
primetime5.0 is offline
Old 02-22-2007, 12:34 AM
Boss_Hotrod
Boss_Hotrod's Avatar
To drill out the rivets I always use a drill bit that is a little larger than the shank. If you drill from the round head side you will eventually drill out a circle around the shaft and the head will fall off. Then you can just push the rivet out the back.
Boss_Hotrod is offline
Old 02-22-2007, 01:11 AM
niseyd07
niseyd07's Avatar
Thanks, ima give it a try 2mrw
niseyd07 is offline
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
Dalthius
01-19-2006 03:56 AM
Scooterman
05-12-2005 11:44 AM
black89gt
03-12-2005 08:08 PM
Quick Reply: Question... rivets
