Ok help me with my check list
Ok allmost done with the build motor had to come back out
306 short block started
e cam
ford racer roller lifters
new pushrods 1.7 rockers new arp head bolts
gt40 upper an lower
gt40x heads
oil pump an that stuff
oil pan msd dizzy
harmonic blancer
water pump
timing chain cover
hmmm just checkin with u guys am i missin something lol
e cam
gt40 upper an lower
gt40x heads
oil pan msd dizzy
harmonic blancer
water pump
timing chain cover
RE: Ok help me with my check list
You're wasting a lot of money on things that are unnecessary. Do you NEED a new oil pan/water pump/timing chain cover? If you do then go for it, if not then it's a waste of money. At this point you do NOT need a new balancer, distributor, or oil pump. For the price of the GT40X's there are a lot better heads to be bought. I'd go with AFR 165's, TF intake, and a custom grind cam. 1.7's are good, but if you already have them the pedestal mount style you probably have won't work on AFR's or Trick Flows (stud mount). Or, you can go with a Trick Flow top end kit and be looking at 300ish rwhp with supporting mods. I'd go with one of those options personally.
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
