351w heads?
Old 02-23-2007, 04:36 PM
pastfast125
pastfast125's Avatar
Default 351w heads?
I was just readin an article in muscle mustangs and fast fords. They were doing a comparison in times between a c4 and t5. On they're test car, I think it was a 91 lx hatchback or somethin, it had a 302 with 1971 351w heads. I didn't know you could run those. Is There a benefit of running stock 351w heads over stock 302 heads? The 351w heads I can get are free, but they're 1991... Any increase in flow or anything to switch those? Does everything bolt up?Thanks.
pastfast125 is offline
Old 02-23-2007, 05:56 PM
grumpyphillips
grumpyphillips's Avatar
Default RE: 351w heads?
I don't know about flow numbers but you should be able to bolt 351 heads up to a 302 without any problems.
grumpyphillips is offline
Old 02-23-2007, 06:20 PM
pastfast125
anybody know if there would be benefits?
Old 02-23-2007, 06:31 PM
fordstroker
I ♥ Acer
fordstroker's Avatar
The C9-D0 351 head is comparable to a gt40 head, the later heads like you have are useless.
fordstroker is offline
Old 02-23-2007, 06:34 PM
90mustang5.8
I ♥ Acer
90mustang5.8's Avatar
the 351w heads have bigger valves.........
90mustang5.8 is offline
Old 02-23-2007, 06:38 PM
dthompson67
dthompson67's Avatar
yes the 351w heads bolt up just fine. actually my friend is building a 347 using 351w heads. he is porting out the hump in the exhaust ports to allow more airflow.
dthompson67 is offline
Old 02-23-2007, 06:42 PM
93whitelx
93whitelx's Avatar
ORIGINAL: dthompson67
well his heads are junk now , never port your heads, unless he has a shop do it
93whitelx is offline
Old 02-23-2007, 06:43 PM
pastfast125
ic. So would there really be any benefit to swapping out the later yr 351 heads, and maybe doin what he said with just cleanin up the ports a lil bit?
pastfast125
woops, you beat me... n/m
Old 02-23-2007, 06:44 PM
90mustang5.8
I ♥ Acer
ORIGINAL: 93whitelx
wtf?
Quick Reply: 351w heads?
