Push Rod Question
Old 03-01-2007, 01:48 AM
Dubs
Dubs's Avatar
Default RE: Push Rod Question
Thank you for your kind words. Seriously I wish I had more time on my hands to. I guess thats my main reason also. I know what parts are needed but putting it together is what gets me. How did you do yours?
ORIGINAL: LTnone
You don't necessarily need to be super mechanically inclined to do a h/c/i, I wasn't before I did mine either. A good set of directions/shop manual and a bit of common sense will do wonders. I'd really recommend doing it on your own, for the money and fun yeah, but mostly you learn so much doing it....definitely do if you at all can
Dubs is offline
Old 03-01-2007, 02:09 AM
Li0nHart
Li0nHart's Avatar
ORIGINAL: LTnone
This question has come up about once a day for the past week
WE DON'T KNOW. GET AN ADJUSTABLE PUSHROD AND FIND OUT
Not jumpin on ya, but seriously...I hope people start reading threads that pertain to their own questions
k...we can all log off now...no need for new posts cause everything that could ever need to be discussed has been mentioned by now. eveyone just do searches from now on.....
Li0nHart is offline
Old 03-01-2007, 02:16 AM
93whitelx
93whitelx's Avatar
ORIGINAL: Dubs
Ya I got some Hyd Ford racing roller lifter set.I have to talk to my friend about the roller rockers. I was thinking aboutthem but he nver mentioned to me to go ahead and change them out. I agree with you..maybe I should since I'm there already.
No I havent put my stuff on yet. I'm actually having someone else do it. Man I wish I was technical savvy so I dont have to pay someone to do it.
if you mess with the rocker arm ratio make sure you get the right length push rods too
93whitelx is offline
Old 03-01-2007, 02:19 AM
Dubs
Dubs's Avatar
Thanks. Thats what Im trying to figure out the correct length of the push rod
ORIGINAL: 93whitelx
ORIGINAL: Dubs
Dubs is offline
Old 03-01-2007, 02:23 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: Li0nHart
ORIGINAL: LTnone
Thats kinda the idea behind the search function... its there to make your noob life miserable
AdderMk2 is offline
Old 03-01-2007, 02:32 AM
Dubs
Dubs's Avatar
It's tough being a nood! But hey we all go through it right.
ORIGINAL: AdderMk2
ORIGINAL: Li0nHart
ORIGINAL: LTnone
Dubs is offline
Old 03-01-2007, 02:34 AM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: Dubs
I never had any "noob" problems when I joined this site...
then again, I actually READ the forum... and I SEARCH things... and GOOGLE is your friend
AdderMk2 is offline
Old 03-01-2007, 02:37 AM
Dubs
Dubs's Avatar
Ya your right. Maybe I'm just a noob all around. I hear your the guy that knows about tires sizes and stuff. I'll be hitting you up for those types of questions, is that ok?
Dubs is offline
Old 03-01-2007, 05:08 AM
Chitown racer
Chitown racer's Avatar
The best way to figure out what pushrod length you need is to use an adjustable pushrod made for that very purpose. Once you have it the the right length than have it measured by someone with the right equipment ( usually your local machine shop) and order 16 of them. With that said, the variablessummit was talking about are deck height, gasket thickness, and cylinder heads deck thickness. If you havent had your block decked, your heads milled, and your using a head gasket thats the same thickness as stock (.039-.040) then your just compensating for the increased deck thickness thats common toaftermarket heads like your Trick Flows.In cases like these most of the timeyou canjust order a set of pushrodsthat are.080 to .100 longer than stock and you'll be good. I'm not going to say that it will be so in your case, but speaking from the experience it is usually the case. It couldnt hurt to give it a shot worst case senerio is you have to exchange them for the right size.
Chitown racer is offline
Old 03-01-2007, 02:14 PM
LTnone
LTnone's Avatar
ORIGINAL: Dubs
ORIGINAL: LTnone
Honestly I just kinda went at it with a shop manual and a prayer. There's a great writeup on directions step by step (below), it was helpful for tearing stuff down but I was able to stop using it and just figure it out on my own. A bit of common sense goes a long way in the engine building world. However, it also has its limits- be sure to cross reference EVERYTHING you do with a shop manual. I would have missed a million small things, like greasing the ends of the pushrods, putting RTV on certain things, or one of a million others. Also, be sure to put every bolt you remove in cardboard and label what it is. If you're not sure if you'll remember how something came apart/goes back together, take a picutre of it, maybe make a note. You'll do fine if you just make sure you're doing what you're supposed to. Here's that article, the one thing about this is on step #24 it doesn't say anything about taking the lifters out, but YOU NEED TO REMOVE THE LIFTERS BEFORE TAKING OUT THE CAM! If not they will make close acquaintences with your oilpan. Also, replace the lifters. Just do it. If you absolutely must keep the stock ones though, make a note of exactly where each lifter went, and also which direction it was pointed (so the cam rolls the same direction on it). Nevermind which end went up and which went down PM me if you have any questions. Good luck!
http://www.allfordmustangs.com/techa...intakeswap.pdf
LTnone is offline
Quick Reply: Push Rod Question
