Best heads for the money
Old 02-28-2007, 10:07 PM
ih8chevy
ih8chevy's Avatar
Default RE: Best heads for the money
lets just say that if ur not going to do any porting, u just want to buy a head and assemble them and put them on than if u got the money afr is the best way to go.
ih8chevy is offline
Old 02-28-2007, 10:08 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
nope!
2 kwik is offline
Old 02-28-2007, 10:09 PM
fordstroker
I ♥ Acer
fordstroker's Avatar
The biggest downside to an afr head, is the valve spring it comes with is useless and should be changed. I have used TFS heads 10+ years ago and they always work well. Plus side to the canfield is they rock and can be had with a spring that you need right out of the box. Not everyone runs them like an afr or TFS and thats reason alone. Who do you think makes all of Jegs private label heads? Thats right, canfield.
fordstroker is offline
Old 02-28-2007, 10:11 PM
PJB
PJB's Avatar
ORIGINAL: 2 kwik
I hate to say this but none because you need to put that $$$ in that transmission which is your wink point and the heads will only make that more apparent
Im putting a shift kit in it (already have it) and getting a stall converter (probably 2400).
Other than that Im not doing anything else to the transmission. Im keeping the AOD in there.
PJB is offline
Old 02-28-2007, 10:13 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
you should put in a better servo and a valve body instead of just a shift kit..your trans will thanks you
2 kwik is offline
Old 02-28-2007, 10:15 PM
PJB
PJB's Avatar
ORIGINAL: Evil_F
Best for your money
World Products Windsor Sr Cylinder Heads
Valves = 2.02 & 1.6in + 200cc intake runners, C.Chamber is 64cc (has its +'s & -'s), they are iron but they are cheap when compared
Best Aluminum Head I found for yur' muny'
Edelbrock Performer RPM Cylinder Heads
Valves = 2.02 & 1.6, 170cc intake runners, C.Chamber is 60cc
The Best deal I found was on bare (not assembled) heads
Edelbrock Victor Series Race Cylinder Heads
Valves = 2.125 & 1.625, 240cc I.runners & 80cc E.runners, C.Chamber is only 47cc (for a N/A)
Thanks. I definately want assembled aluminum heads.
I was actually going to buy a set of those Edelbrocks off my brother's friend but he cant afford to change the heads on his 331 this year so he's keeping them on.
He actually said I should get AFR's instead of the Edelbrocks he has though.
PJB is offline
Old 02-28-2007, 10:16 PM
fordstroker
I ♥ Acer
Oh ya who makes the Z304 ford head? Thats right canfield, its a bad ****, who make the heads for turbo buick V-6 guys? Canfield.
Old 02-28-2007, 10:17 PM
PJB
PJB's Avatar
ORIGINAL: 2 kwik
I dont really want anything thats a pain to drive on the street though. This car is mainly a street car even though I do take it to the track.
PJB is offline
Old 02-28-2007, 10:20 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
it won't be a pain it will help to be more reliable
2 kwik is offline
Old 02-28-2007, 10:21 PM
PJB
PJB's Avatar
ORIGINAL: fordstroker
Are the AFR springs useless even with a mild street cam? Im not putting any crazy race cam in the car.
Are the heads Canfield makes for Jeg's the same exact heads as sold under the Canfield name or are they of lesser quality and performance?
PJB is offline
Quick Reply: Best heads for the money
