Low Rpm Bogging... Plug wires?
Old 03-03-2007, 02:48 AM
ckyguy68
ckyguy68's Avatar
Default Low Rpm Bogging... Plug wires?
Bogs at low RPM under a load. Its even worse when its raining out... i really think its the plug wires but i need some verification.
ckyguy68 is offline
Old 03-03-2007, 03:27 AM
93 LX FiveO
93 LX FiveO's Avatar
Default RE: Low Rpm Bogging... Plug wires?
my car does the same thing.. 1/4 throttle it at like 1200 rpm's and it bogs. my plugs arent even 6 months old.
93 LX FiveO is offline
Old 03-03-2007, 03:35 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: ckyguy68
How does it run when the weather is good?
PRO50SC is offline
Old 03-03-2007, 03:39 AM
ckyguy68
ckyguy68's Avatar
It doesnt do it as bad, but you can still feel a slight bogging at low RPM. Another thing is when the car is cold it does it worse than after it warms up.
ORIGINAL: PRO50SC
ORIGINAL: ckyguy68
ckyguy68 is offline
Old 03-03-2007, 03:42 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
ORIGINAL: ckyguy68
ORIGINAL: PRO50SC
ORIGINAL: ckyguy68
Generally, if it was the wires, it would do it more after it warms up. As the engine component get hotter, the wires create more resistance, in turn takes more for the spark to travel thru them. Are you mistaking bogging for missing? Use the correct term b/c the 2 words have different meanings.
PRO50SC is offline
Old 03-03-2007, 03:48 AM
ckyguy68
ckyguy68's Avatar
It feels like it its not getting enough spark. Ive had my plug wires ground out on the headers before and it felt similar, just not as severe.
ckyguy68 is offline
Old 03-03-2007, 03:49 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Well one thing you can try, take a spray bottle full of water and spray down the wires and see if it gets worse. How old are they?
PRO50SC is offline
Old 03-03-2007, 03:53 AM
ckyguy68
ckyguy68's Avatar
They have AT LEAST 13,000 miles on them. They were on the car when i bought it, and ive put 13 on the odom. They are cheap murrays ones so i think that may be the problem.
ORIGINAL: PRO50SC
ckyguy68 is offline
Old 03-03-2007, 10:29 AM
dimebag
dimebag's Avatar
ok so go buy wires....
dimebag is offline
Old 03-03-2007, 10:35 AM
ROTTITANK
ROTTITANK's Avatar
See ifany water is getting incap and rotor. Gm has a problem with there 4.3s getting water in them. Causing it to bog when it raining or damp out.
ROTTITANK is offline
Quick Reply: Low Rpm Bogging... Plug wires?
