Torque box reinforcements in today!
Old 03-03-2007, 06:24 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Default Torque box reinforcements in today!
Well, I finally got some time to work on the car today. Went smooth for the most part. The lowers were a breeze, took about an hour for both sides.
The uppers, well that was another story. Took out the upper control arms, the cat back off too. (needed more room to drill) That was about another 3 hours Also found out I need new bushings in the rear where the uppers attatch to the housing.And to top it off, now there's some annoying squeak in the suspension on the right side. I guess when I do the bushings I'll look into that then. Here's some pics from today!!
Empty lower box from underneath
Had to scrape off the sound deadening material inside and remove the plactic body plug....
Lower in place ready for drilling.....
Cleaned up the holes before laying down the inside plate....
Inside plate in place w/ bolts.....
Veiw from underneath, lowers are done....
Uppers..... I slacked on the pics cuz I was having my *** kicked and forgot to take pics of the plates from under the car
Upper control arm removed...
The plate bolted down inside the car....
Pretty much it, cleaned everything up, put the seat back in and DONE!!!!
I locked the other thread cuz it is now in the tech article section. This one is open for w/e questions/comments you may have.
PRO50SC is offline
Old 03-03-2007, 06:45 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
Default RE: Torque box reinforcements in today!
did u weld nething???? i heard its good to do that??? whats you opinion on welding them in after bolting them on?? also did u have to remove the rear end??? i was thinking if one were goin to weld it in the rear end would get in the way
CrazyCobraSpeed is offline
Old 03-03-2007, 06:52 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Didn't weld, (not going to either) nothing else removed other than what I posted.
PRO50SC is offline
Old 03-03-2007, 07:00 PM
CrazyCobraSpeed
is it worth welding them in??? or is it more time and trouble than its worth??
Old 03-03-2007, 07:09 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Not sure on that one. I know ppl do it. I won't be one of them though!!
PRO50SC is offline
Old 03-03-2007, 07:15 PM
5.0stanger
5.0stanger's Avatar
I didn't weld mine either...I looked at my welder, then at the car and said **** on it...It will be fine and a lot less work.
Where did you get yours from?
5.0stanger is offline
Old 03-03-2007, 07:17 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
They are UPR's.
PRO50SC is offline
Old 03-03-2007, 07:21 PM
CrazyCobraSpeed
well u see the thing is im doin all my suspension more or less at once at my uncles farm when i get it and while i have him help me weld in the subframes i was just wondering if it would be worth it go at it... but i was thinking id have to drop the rear end out just to get to them with a welder
5.0stanger
5.0stanger's Avatar
Were you dissaponted like me after paying for them and seeing that ther isn't much to them?? I almost sent mine back and made my own(I am a cheap ***)
Install looks good, good job with pictures also.
Old 03-03-2007, 07:22 PM
CrazyCobraSpeed
oh yea what brand to you 2 recommend??
Quick Reply: Torque box reinforcements in today!
