12's
Old 03-04-2007, 11:10 PM
  #21
92hatchLX
92hatchLX's Avatar
Default RE: 12's
ORIGINAL: 15austin
+1 on all of this Removing the front swaybar is an automatic tenth. Take the rest ofyour $1500 and start buying bolt ons. Without going the nitrous route it will be hard to get low 13s with just $1500,coming from a stock mustang.
ORIGINAL: luckythirteen13
how much do you want to spend? you can easily spend thousands just on the suspension
new upper and lower control arms and some good shocks to start in the rear.
subframe connectors for better weight transfer
new struts for the front. remove the front sway bar
Correct me if I am wrong, but the only advantage of removing your front sway bar is reducing weight. I'm pretty sure that the sway bar doesn't weigh anywhere near 100 lbs, how do you expect todrop a 1/10th secondfrom just removing it?
92hatchLX is offline
Old 03-04-2007, 11:21 PM
  #22
PONY GUY
PONY GUY's Avatar
Default RE: 12's
he wants to get in teh 12's well removing weight helps to . He could also relocate his battery to his trunk
PONY GUY is offline
Old 03-04-2007, 11:28 PM
  #23
92hatchLX
92hatchLX's Avatar
Default RE: 12's
ORIGINAL: PONY GUY
I am fully aware thatreducing weightcan reduce your 1/4 mile times. But what I was referring to is that he said that byremoving your sway bar, you can drop a tenth. The only way that I could see that happening is if the sway bar weighed around 100 lbs (which I'm sure that it doesn't).
Old 03-04-2007, 11:30 PM
  #24
FullAuto
FullAuto's Avatar
Default RE: 12's
ORIGINAL: 92hatchLX
It also helps free up the front end movement and allows for better weight transfer. This is a factor in seeing these cars pull the front driver's wheel higher than the passenger side.
FullAuto is offline
Old 03-04-2007, 11:34 PM
  #25
92hatchLX
92hatchLX's Avatar
Default RE: 12's
ORIGINAL: FullAuto
ORIGINAL: 92hatchLX
Thanks for the info FullAuto. Is it really worth a 1/10th though?
Old 03-05-2007, 12:00 AM
  #26
FullAuto
FullAuto's Avatar
Default RE: 12's
ORIGINAL: 92hatchLX
ORIGINAL: FullAuto
ORIGINAL: 92hatchLX
I wouldn't give it quite that much credit. I guess it would just depend on the car.
FullAuto is offline
Old 03-05-2007, 12:12 AM
  #27
92hatchLX
92hatchLX's Avatar
Default RE: 12's
ORIGINAL: FullAuto
ORIGINAL: 92hatchLX
ORIGINAL: FullAuto
ORIGINAL: 92hatchLX
Do you think that I would really benefit anything from it? Iusemy foxmainly fordrag racingon the street and strip, sometimes I'll drive it to work and school.
