Throttle Response
Old 03-05-2007, 11:48 AM
LTnone
LTnone's Avatar
Default RE: Throttle Response
Get yourself some ignition components
www.malloryperformance.com
LTnone is offline
Old 03-05-2007, 12:11 PM
88BlueGT
88BlueGT's Avatar
+1 on Mallory!
88BlueGT is offline
Old 03-05-2007, 12:16 PM
89 fox
89 fox's Avatar
billet aluminum flywheel
89 fox is offline
Old 03-05-2007, 12:28 PM
r.barn
r.barn's Avatar
have you bumped up the base timing?
I noticed a nice increase in throttle response when i bumped base timing up.
r.barn is offline
Old 03-05-2007, 02:02 PM
LCBlackDep183
LCBlackDep183's Avatar
Just a thought, run some Seafoam through it... CLEAN the throttle linkage then lube it with some white lithium grease(please clean it first think about it...) and adjust those things and it should be fixed...
LCBlackDep183 is offline
Old 03-07-2007, 01:56 AM
AlabamaCobra
AlabamaCobra's Avatar
awesome i seafoamed it through the vacuum booster hose, it started running good so i decided to play around some with the slicks and got the gas pedal wedged into the floor mat at WOT nearly wrecked then nearly blew the fugger up before i turned it off.! hah seafoam did the trick though.
AlabamaCobra is offline
UrS4
10-03-2015 06:23 AM
guitarman376
09-30-2015 05:54 PM
FivePointToTheOh
09-29-2015 12:53 PM
CS2007
Florida Regional Chapter
09-29-2015 12:06 PM
94stangnewbe
V6 General Discussion
09-07-2015 07:39 PM
Quick Reply: Throttle Response
