what springs?
Old 03-05-2007, 10:13 PM
live4motocross11
live4motocross11's Avatar
Default what springs?
i was going to go with eibach pro kit but i dont want to need caster camber plates. ive heard of lots of people that dont but im not sure, otherwise im going to go with ford c springs. Well any adivse and pictures would be awsome
live4motocross11 is offline
Old 03-05-2007, 10:57 PM
bobbyward
bobbyward's Avatar
Default RE: what springs?
the plates mainly give you a extra inch
you have around 4 or so inches to start with and lower it 1 1/2 inches that extra gain back from the plates just help with bottoming out , and adds some extra adjustments, i have them on all 3 of our
mustangs
bobbyward is offline
Old 03-06-2007, 02:23 AM
OnyxCobra
OnyxCobra's Avatar
I would get some H&R springs, they sit so sexy. I have zero complaints about mine. Just get CC plates, thats the right way to do it.
OnyxCobra is offline
Old 03-06-2007, 03:43 AM
Arno
Arno's Avatar
How is the ride with the H&R's? Which set did you get?
Arno is offline
Old 03-06-2007, 03:56 AM
OnyxCobra
OnyxCobra's Avatar
The ride is good as long as you have aftermarket struts and shocks, it might be a li'l rough/bouncy with the stock ones. I have the SuperSports, the Sports dont sit qutie as low and aren't as stiff, both look very good. I wanted my car pretty low so I went with the SuperSpots
Old 03-06-2007, 07:37 AM
w8less
w8less's Avatar
i had the bbk lowering springs on mine and didn't need C/C plates on it. they were able to do the alignment just fine
(those were both when the car was pretty much stock)
when the car was lowered with k-member and coil over kit
last pic of the car i took^^^
there was a slight difference in the ride height mainly due to the adjsutability of the coilovers
w8less is offline
Old 03-07-2007, 12:07 AM
live4motocross11
i mean im spending so much idk if i wanna go loww and need cc plates
Old 03-07-2007, 12:21 AM
AdderMk2
Banned
AdderMk2's Avatar
It would be wise of you to just buck up and buy CC plates. As you lower the car, your caster will be WAY off... and im sorry jasper.. But I know for a fact that the alignment shop didnt get your car perfect... you CAN NOT adjust caster far enough on stock adjustments... I know this because I do alignments... and I needed CC plates to get MY car straight
AdderMk2 is offline
Old 03-07-2007, 12:36 AM
Foxbodyforever
Foxbodyforever's Avatar
if your really don't want C/C plates then the c springs are the max that your stock suspension will hold, any lower and your gonna break something, i've got b springs cuz i didn't have the cash for C/C plates
Foxbodyforever is offline
Old 03-07-2007, 07:34 AM
w8less
w8less's Avatar
ORIGINAL: AdderMk2
it was good enough where it didn't where the tires out any. those were the same rims and tires that were on the car for 3yrs and never rotated them.
w8less is offline
Quick Reply: what springs?
