taurus fan
taurus fan
http://forums.hybridz.org/showthread.php?t=99700
i didnt know if anyone did it this way or not. i know what i have to do but just the parts i need i am not sure what i need to get, this guy kinda stumped me
RE: taurus fan
I used a Lincoln Mark VIII fan, same basic fan
you need 10g wire from fan to good ground
10g wire with 30-40amp relay to starter solenoid
then i ran a 12g wire from relay thru firewall to fuse box
on lower dash for "switched" power source,
Fan comes on with the key, you can also put a switch in line
with that switched wire and be able to turn off fan with key on if needed
His way works the way you would expect a factory fan to work
I just hooked mine up on high and leave it on.
Seanam
10-04-2015 10:15 AM
09-25-2015 09:06 AM
