Removing smog pump and A/C
Old 03-08-2007, 01:28 AM
Bran411
Bran411's Avatar
Default Removing smog pump and A/C
Ok here is what I got. I want to remove the smog pump, A/C, and add underdrive pulleys to my 83 Mustang 5.0. Question is do I have to go back with a smog pump and A/C eliminator bracket and pulley or can remove them all together? And what will the underdrive pulleys do for me?
Bran411 is offline
Old 03-08-2007, 01:36 AM
deanzawistowski
deanzawistowski's Avatar
Default RE: Removing smog pump and A/C
ORIGINAL: Bran411
take out both systems completely and plug all holes (on the back of the cylinder heads and midpipe)
buy the bracket from ford that relocates the power streering pump to where the A/C is
Underdrive pullies will slow down your accessories, you see in increase in about 5 hp from them, maybe more
this diagram should help
[IMG]local://upfiles/41517/C41E6CF74F41482BA9DEA73352790287.jpg[/IMG]
deanzawistowski is offline
Old 03-09-2007, 01:32 AM
Bran411
Bran411's Avatar
Where do i get the bracket?
Bran411 is offline
Old 03-09-2007, 04:05 AM
LCBlackDep183
LCBlackDep183's Avatar
https://mustangforums.com/upfiles/41...3352790287.jpg
Just a sidenote to that image, if your running a sn-95 the 70.5" belt will bypass the AC and Smog...
LCBlackDep183 is offline
69Volunteer
09-30-2015 10:39 AM
b8checker
09-30-2015 07:11 AM
fastbackford351
Convertible Tech
09-27-2015 06:51 AM
SteelerNation82
09-16-2015 07:11 AM
wawagner82
09-13-2015 09:02 AM
Quick Reply: Removing smog pump and A/C
