violent virbration
Old 03-10-2007, 11:42 PM
green95GT
green95GT's Avatar
Default RE: violent virbration
well i don't know if the car wash shot water up underneith. I've gone through that carwash before. and i think its vibrating because its missing. but im not sure
green95GT is offline
Old 03-10-2007, 11:44 PM
ZachW04Stang
ZachW04Stang's Avatar
ORIGINAL: green95GT
i check all my wires and they are all on there good. Could it be my harmonic balancer.
How did you check your wires? A harmonic balancer isn't just going to go bad all of a sudden and cause a horrible vibration. Do you still have the rubber distributer cover on your car? Does the car shake when its not moving? Did the car start shaking once you took it through the car wash?
ZachW04Stang is offline
Old 03-10-2007, 11:49 PM
green95GT
green95GT's Avatar
i came home right after the car wash then the next morning it did that. and it shakes as soon as i start it.
Old 03-10-2007, 11:54 PM
ZachW04Stang
So we know it isn't the driveshaft since it does it at idle when the car isn't moving.It started up suddenly right? There were never any signs of a vibration before you went through the car wash? Do you have the rubber distributer cover on the engine still?
Old 03-11-2007, 12:13 AM
green95GT
green95GT's Avatar
i have a msd distbrutor cap. and the distrubator is still tight it hasn't moved to mess up the timeingso if i think i know what you are talking about its still good
Old 03-11-2007, 12:17 AM
90Lxstanger
90Lxstanger's Avatar
So does it vibrate all through the rpm band? and it does it in neutral, so like said above its not driveline. It must be spark or something?.............
90Lxstanger is offline
Old 03-11-2007, 12:20 AM
tmajikman
tmajikman's Avatar
You might want to pop the cap off and make sure it is bone dry, only takes a minute, if its wet it will run horribly.
tmajikman is offline
Old 03-11-2007, 12:25 AM
green95GT
green95GT's Avatar
ya i already checked the distrubuter cap bone dry. And at about 3 grand it seems like it smoothes out a little on the virbations but still vibrates quite abit
Old 03-11-2007, 06:01 PM
green95GT
green95GT's Avatar
ok so i started looking at it again. and my dad suggested to add heet to the tank and i did. and now it seems to be idling lower and when it is below 1 grand rpm right around 500 rpm it doesn't seem to vibrate as bad. i check the dirstubertor cap again and there is no moister.
ANY IDEAS.
need the car working to day. so i can drive to school tomarrow
thx
Old 03-11-2007, 06:45 PM
green95GT
green95GT's Avatar
ok so i went to start it up again and i turned it over the first time didn't fire so i went to turn it over again and this time it just started clicking. nothing. so i thought maybe dead battery. so i went to jump start it and it barely turned over not even close enough to start.
Quick Reply: violent virbration
