ECT location Q, almost done.....
Does the ECT go in the end of this tube ? Or does it go where i have it ? I can either block the end of that tube, or put the ECT there and block the hole its in.
[IMG]local://upfiles/24448/0B7359321935435AAF67141851766E5E.jpg[/IMG]
RE: ECT location Q, almost done.....
Well, On my car, theECT is in the tube. In the intake where you have the ECTthe sensorfor the gaugegoes there(one wire hookup) I don't think it is right, but it should work fine as long as you plug the hole.
I got the 1 wire sensor in the back, so it is hooked up. I think ima just plug the hole whre the ect is now and put the ect in the end of that pipe.
On mine, the ECT goes in the tube that runs to the heater core, which is in your pic, but i cant see it, the Engine Coolant sender is correct though, which im assuming your running a stock gauge-cuz it has a electrical connection.
ORIGINAL: 90Lxstanger
ORIGINAL: 5.0stanger
The gauge temp sensor is in the picture, that is the ECT in place of where it goes...the gauge temp sensor has only 1 wire.
Matt's 95 Stang
10-05-2015 07:16 AM
