did i goof......mass air
ok, i purchased a 80mm mass air calibrated for 30lb injectors about 2 months ago (off of ebay)and i had not even looked until today, i have a 91gt, the writing on the side says calibration for a 96gt /30lb injectors, do i need to sell it and get a different one? also it has a flat back to bolt something to its not a front and rear circle like my original.
thanks
thanks
RE: did i goof......mass air
ORIGINAL: capri debris
No don't sell it... just check out Late Model Restoration and get the right calibration tube for your car.
lol newb
doesnt matter what "tube" you put in... the valtages are wrong.... Do myself and VRIStang a favor and NEVER give any MAF advise again.
Actually Adder,
The newb has a point...
If it is a C&L meter the sample tube can be changed, and the MAS (sensor) can be swapped for a Fox MAS.
That is assuming we are talking about a C&L meter though...
If it is a PMAS (or anything other than C&L), then you are still out of luck.
Sorry I didn't think to ask that sooner...
jason
jason
If its a C&L meter, the entire sensor could be changed, which would be the ONLY way it would work.. however, I would be willing to bet that since it is from a 4.6l motor, the values in the transfer would be vastly different and could not be installed without a EEC re-flash. Sorta like using a lightning maf
ORIGINAL: zemog
its a pro flow. and unless they make an adapter or something how would you bolt it up if one end is square and the other round?
z
z
Good Luck,
jason
daltron
04-28-2016 08:10 PM
