world windsor seniors anyone?
Old 03-16-2007, 10:36 PM
PONY GUY
PONY GUY's Avatar
Default RE: world windsor seniors anyone?
i just didnt know i f you wre planing on up grading pistions too since you were going that far . I would do a whole rebuild you would save money in the long run
PONY GUY is offline
ih8chevy
ih8chevy's Avatar
why do they need to be notched? or should i get some diff pistons?
ih8chevy is offline
Old 03-16-2007, 10:39 PM
PONY GUY
PONY GUY's Avatar
nois not necessary but with all the money you are spending I would do a full rebuild on the engin and the pistion upgrade would make help you gain the most performance out of all you upgrades
PONY GUY is offline
Old 03-16-2007, 10:44 PM
ih8chevy
ih8chevy's Avatar
well the thing is im tryin to stay out of the motor for the most part, i.e money and time. but i will consider the rebuild. plus the block im using 87-92 already has forged internals. so. will i need to notch the stock pistons like the afr185's or are they fine by themselves?
ih8chevy is offline
Old 03-16-2007, 11:04 PM
my77stang
my77stang's Avatar
if you notch the stock pistons your gonna throw the balance outta whack, so everything will need balancing. i cant tell you if the valves will hit, it depends on valve size, the pistons, and the cams lift.
those windsor heads you are talking about are designed to work on any small block ford, doesnt matter 289/302/351w
without knowing flow numbers i would say the AFR 165's are prolly on par with the windsor jr's and the AFR 185's on par with the seniors. i do know that i hear ALOT about AFR, they seem to be pretty widely recognized as excellent heads for SBF's. also dart's, canfields, trick flows (the R heads are wicked but for very high HP applications), even the edelbrocks are nice once your up into the victor jr range heads.
my77stang is offline
Old 03-16-2007, 11:07 PM
PONY GUY
PONY GUY's Avatar
ORIGINAL: my77stang
yeah keep every thing balace and notching is not needed I like the ww jr's becuse they can handle a pretty big shot of nitrous
PONY GUY is offline
Old 03-16-2007, 11:16 PM
ih8chevy
ih8chevy's Avatar
alright guys i think i got it. so the wws's would be the way to go for me or the juniors. i meani kno that they are a big head but i think that with the cam im going to use it wont be a big deal. oh and the cam im usin is either
trick flow stage 2 542/563 lift 286/294
or
comp cams xe294h 554/558 lift 294/306
ih8chevy is offline
Old 03-17-2007, 12:46 AM
ZachW04Stang
ZachW04Stang's Avatar
I don't think those windsor srs are going to work out too go on a stock 302 pistons. At my shop we have a stock short block 302 w/ windsor srs and b303 cam and when you spin the motor by hand the valves touch the pistons. I'd hate to see what would happen if someone tried to start it up.
ZachW04Stang is offline
Old 03-17-2007, 01:25 AM
ih8chevy
ih8chevy's Avatar
honestly im most likely goin to use a gt40 head for the reason that its more impressive if u say its all ford components with just a cam. but i was just trying to find info on the windsor senior heads.
ih8chevy is offline
ih8chevy
ih8chevy's Avatar
and i figured i would have a problem when i put those huge cams in the mix
ih8chevy is offline
Quick Reply: world windsor seniors anyone?
