New Set Up Needs Predictions
Old 03-18-2007, 04:57 AM
91RedHatchback
91RedHatchback's Avatar
Default New Set Up Needs Predictions
I am gonna be receiving my intake, throttle body, and egr plate sometime on monday. What kind of hp do you think that I willget out of the engine andat the wheel once i set it up? Im currently working on getting my gears and a valve and shift kit for my transmission too but thats gonna have to wait till the summer. . . maybe.
Class II 302 Jasper Engine (Dyno 310hp)
Trick Flow EFI Intake Manifolds
Trick Flow EFI Heat Spacer Kits
75mm Summit Racing Street & Strip Throttle Body
75mm Summit Racing Street & Strip EGR Plate
75mm/24lbs Mass Air Flow Sensor
Cold Aid Induction System
K&N Air Filter
Ford Racing 24lbs Injectors
Adjustible Fuel Pressure Regulator
A/C Eliminator
Smog Pump Eliminator
BBK H-Pipe w/converters
High Per. Stage I AOD Non-Lock Up Converter
New Fuel Tank
Proform Electric Fan
MSD Blaster TFI Ignition Coil
9mm Ford Motor Sport Spark Plug Wires
91RedHatchback is offline
Old 03-18-2007, 05:08 AM
iceman89gt
iceman89gt's Avatar
Default RE: New Set Up Needs Predictions
u should be around 300 or so. you really need some heads and a cam for more. i would say no more than 300.
iceman89gt is offline
Old 03-18-2007, 05:20 AM
91RedHatchback
some heads and a cam would help it out, but i realy don't want to void the warranty by getting inside the engine right now. Ill get those once warranty for the engine expires. Nice rims by the way iceman, been looking for some of those what did you pay for them?
Old 03-18-2007, 05:31 AM
w8less
w8less's Avatar
i have use to have a jasper motor in my car (hence the name) and that warranty doesn't cover SH*T! i regret getting that motor than anything i have ever done in my life
w8less is offline
Old 03-18-2007, 05:35 AM
91RedHatchback
Ive been told that jasper made good engines. why do you dissagree? what happened to yours?
Old 03-18-2007, 06:14 AM
w8less
w8less's Avatar
after i got the fuel pump went out. warranty to didn't cover it they said it didn't relate to the engine. replaced the fuel pump. then the regulator went out and wasn't holding enough pressure for the car to start. it is on the motor it they wouldn't cover that. then the ignition module went out they wouldn't cover that had to buy one. then i got a header leak they wouldn't cover that. Over all i PI$$ED 99% of the time and i wish i would have just bought what i wanted and could have modded it the way i wanted. as you can tell i said FU*K the warranty and did what i wanted since it didn't cover anything. also you do know if you race the car it will void the warranty
w8less is offline
Old 03-18-2007, 10:49 AM
AdderMk2
Banned
AdderMk2's Avatar
since it looks like your not running aftermarket heads, or aftermarket cam.... i'd say you have a slim chance at breaking 250rwhp....
AdderMk2 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
TCStangerv6
10-11-2015 05:57 PM
mustangheaven
10-07-2015 10:23 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: New Set Up Needs Predictions
