help with broken torque box
Old 03-20-2007, 09:16 PM
JURKMYSTIQ
JURKMYSTIQ's Avatar
Default help with broken torque box
i need help or anyway i can fix my torque box? i broke my right upper torque arm. thanks
JURKMYSTIQ is offline
Old 03-20-2007, 09:20 PM
AndySpeed
AndySpeed's Avatar
Default RE: help with broken torque box
gonna have to weld the box back on.
AndySpeed is offline
Old 03-20-2007, 09:27 PM
luckythirteen13
luckythirteen13's Avatar
id go to a frame and alignment shop so that everything will be lined up correctly when its welded
luckythirteen13 is offline
Old 03-20-2007, 09:39 PM
dman302
dman302's Avatar
ORIGINAL: luckythirteen13
I would change "id go" to you will HAVE to go to a frame or.....the box needs to be repaired properly, not only to hold but for location as well...rear end alignment will be seriously affected.
dman302 is offline
Old 03-21-2007, 01:26 AM
tortugasmoker
tortugasmoker's Avatar
hey mine was broke and fixed when i bought my fox, same one actually,glad to see im not the only one
im gonna buy thattorque box reinforcementfrom wild rides race cars. you should check those out wildridesracecars.com
tortugasmoker is offline
Old 03-21-2007, 02:03 AM
1BIGMOFO
1BIGMOFO's Avatar
how much are those things? someone told me if you do upper control arms and traction bars you should reinforce the torque box... I dont have any rust up there at all. could I still be in danger?
1BIGMOFO is offline
Old 03-21-2007, 02:08 AM
Blue Oval
Blue Oval's Avatar
i just put in the upper and lower torque box reinforcements last week, only paid around $80 www.laurelmountainmustang.com was having a sale. how did you break it anyway?
Blue Oval is offline
baddog671
07-26-2016 01:20 PM
daltron
04-28-2016 08:10 PM
guitarman376
09-30-2015 05:54 PM
wraith777
09-28-2015 10:49 AM
09-25-2015 06:58 PM
Quick Reply: help with broken torque box
