cam degreeing
Old 03-26-2007, 02:56 PM
88MustangGX
88MustangGX's Avatar
Default cam degreeing
So my cam is advanced already 2 degree's. i'll probably bump it to 4. Supposidly that improves low end power and gas mileage. Anyone have this done already? any difference? thanks!
88MustangGX is offline
Old 03-26-2007, 03:26 PM
Joel5.0
Joel5.0's Avatar
Default RE: cam degreeing
Yep...have done here.....but you need to know if 4° advanced is 4° and not 6-8°........need to degree the cam and make sure the grind+crankshaft+timing gears tolerances do not place the events somewhere else. For example.....I've installed a few E/B-303's that were 4° advanced when you use the 0° keyway.....among other brands that have been 2° advanced....just a thought.
Joel5.0 is offline
Old 03-26-2007, 03:37 PM
88MustangGX
not sure of what you just wrote but it's at 2 degrees advanced now. i would bump it 2 more to make it a total of 4. It's also the stock cam. not an e/b 303 cam so dont know if that makes a difference or not.
Old 03-26-2007, 04:19 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
he's talking about the different tolerances in the other parts advancing the cam more even though you have the cam sprocket @ 4 degrees advance
2 kwik is offline
BOB ROME
07-26-2023 01:54 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
Explosive
10-02-2015 07:45 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
UrS4
09-30-2015 10:13 AM
Quick Reply: cam degreeing
