Upgrades?
Old 03-29-2007, 08:41 PM
moose7171
moose7171's Avatar
Default Upgrades?
Well I have a 94 mustang GT and i dont know hardly anything about engines. The engine is completely stock. I was wondering what i could do to make it faster such as up grades and stuff?
moose7171 is offline
Old 03-29-2007, 08:47 PM
nitrous_bob
nitrous_bob's Avatar
Default RE: Upgrades?
gears and tires will get the most noticible diff, bumping to 4.10's can knock off 1 full secend, thats like adding 100 horsepower
your existing gears can be decoded like this, on the doortag, under "ax" it will have m=2.73, z=3.08 or e=3.27
is it aod or 5-speed? if aod only go 4.10's no 3.73
or nitrous is great, and also cheap
other mods are not worth doing til you have a full package, like an intake swap does nothing w/ out heads as well, heads are the biggest bottleneck in the motor.
there is also free stuff, make sure your tps voltage is about .990 w/ the key on, but engine not running, you'll need a digital voltmeter.
also a k&n filter, dump off the air sliencer if it happens to still have one, it's mounted behind the air filter cover , you'll know it when you see it.
check to make sure the throttle body is opening all the way when your foot is matted, not using your hand under it.
adjust your timing to 12* (start using 89 and when it's hot use 92 or better)
thats a start, good luck, congrats and welcome
nitrous_bob is offline
Old 03-29-2007, 08:51 PM
moose7171
moose7171's Avatar
Well its a automatic.I am thinkin on spendin around 5000 or so on upgrades for it i just would have no idea on what to get for it.
PaulH2
20
01-31-2016 09:48 AM
jrrhd73must
10-02-2015 09:17 PM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
UrS4
09-30-2015 10:13 AM
Quick Reply: Upgrades?
