Shifter
Shifter
Hey guys got a minor problem with my shifter (manual car) Sometimes the gear doesn't want to go into the proper place. The clutch is all the way down and I have to put it into neutral and move it back and forth and then it goes it. So what I am thinking is that it may need to be adjusted. It almost feels as if I have to force it into gear, not just slide in nicely. Does anyone know of a site that can tell me how to adjust it.
Im pretty sure the shifter is stock btw. My rpms are still being a pain when I shift. Its never smooth how it should be[:@]
Thanks
Thanks
RE: Shifter
if you have the stock quadrant to adjust it put your toes under the clutch peddle and pull it up you will feel it click. then push it to the floor do it like 4-5 times see if that does anything
RE: Shifter
yes might not be disengaging all the way, try to adjust like stated above, lift the pedal. if it helps, get an adj right away, the stock junk breaks and will toast a clutch disc quick
could be worn synchro's too
RE: Shifter
ORIGINAL: iceman89gt
im thinking more like adder along the lines of a shift fork. could also be synchros if its draging.
RE: Shifter
im in no mood to ans. trans. threads tonight, lol. do u have aim?if so im me... disturbed26888... my initial thought is ur clutch is outa adjustment... if its stock, usually the way said above doesnt work u have to do it urself... i can explain the other way if needed.
when u put it in gear and arent moving... do ur rpms drop slightly?
junior04
09-28-2015 10:53 AM
