My Electrical System is Disintegrating !
Old 04-05-2007, 11:23 PM
r.barn
r.barn's Avatar
Default My Electrical System is Disintegrating !
I dont know what the hell is going on.
Been having an ignition problem for last couple of weeks
Runs fine for 20-30mins then just dies like you turned it off.
will crank but not fire off, wait 30mins will start right up.
Did that again today.
While waiting with engine off and key on, the tach would jump 300-400 rpm
and show a voltage drop at same time every now and then.
Tach has done other weird things that the engine was not doing lately also.
Came back 1 hr later and it started right up, but
showing no charge from alternator. hmmm.
Only 1/2 mile to home so just nurse it back,
Get about 5 blocks and
SMOKE POURING OUT OF COWL! YIKES.
pull over and the alternator itself is smoking like a bar-b-q pit. WTF!!!!
brand new alternator.
Take the belt off and unplug the alternator and nurse it home the last
5 blocks.
Anyone have a clue?????
r.barn is offline
Old 04-05-2007, 11:26 PM
mattdel
mattdel's Avatar
Default RE: My Electrical System is Disintegrating !
what electrical devices are you running?
mattdel is offline
Old 04-05-2007, 11:27 PM
frdmstng1986GT
frdmstng1986GT's Avatar
what kind of alt? any wires touching headers anywhere? it almostsounds like you had a cross short from youre alt to youre dizzy or ignition box( hence the tach jumping with the key off ) and it is feeding back into the alt and burnt it up. just a guess though.
frdmstng1986GT is offline
Old 04-05-2007, 11:28 PM
r.barn
r.barn's Avatar
electric fan
cheap radio
its wired up and grounded right up for sure
no aftermarket ignition box, stock
r.barn is offline
Old 04-05-2007, 11:36 PM
frdmstng1986GT
ok, well then it sounds like youre tfi is feeding back to youre alternator or something... it's deffanitly a cross short in my opinion though.
Old 04-05-2007, 11:38 PM
mattdel
mattdel's Avatar
ORIGINAL: frdmstng1986GT
this sounds pretty good
mattdel is offline
Old 04-05-2007, 11:39 PM
r.barn
r.barn's Avatar
already tried swapping TFI modules out.......
I have an inline 150amp fuse between alternator and starter soleniod too.
everything is maticulously grounded and covered and run with proper
fine strand 4g cable. First class 200amp alternator and alternator swap install
No problems with that for thouands of miles
r.barn is offline
Old 04-05-2007, 11:40 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
could just be a bad alt.
PRO50SC is offline
Old 04-05-2007, 11:43 PM
frdmstng1986GT
pro's right, could be a bad diode trio in the alternator.
also, r.barn, have you tried tracing the harness from the tfi module plug and the alternator harness too and see if they come together and cross somewhere?
Old 04-05-2007, 11:45 PM
r.barn
r.barn's Avatar
bad alternator would cause all the dieing problems have been having though
r.barn is offline
Quick Reply: My Electrical System is Disintegrating !
