Building a non-Mustang 5.0
Old 05-09-2007, 12:59 PM
dasfonzie
dasfonzie's Avatar
Default Building a non-Mustang 5.0
Can you build a non H.O. 5.0 to have just as much power as the H.O.?
I like the Lincoln Mark VIIs, It'd be nice to have some power and have a nice luxurious ride too. Of course there's not that good a chance of finding one of these in mint condition, so it would be a restoration project, so I'd probably be replacing a lot of the engine with performance parts anyway
dasfonzie is offline
Old 05-09-2007, 01:02 PM
LTnone
LTnone's Avatar
Default RE: Building a non-Mustang 5.0
Someone correct me if I'm wrong but I'm pretty sure all you need to convert is a camshaft, computer, and harness. Lot more options for the HO, I haven't looked much but you can't really find cams for the non-HO motors.
LTnone is offline
Old 05-09-2007, 01:20 PM
5.0stanger
5.0stanger's Avatar
I am pretty sure they are the same block, just different cam. Maybe they have different pistons to lower compression and the heads might be different also, but you can build them. Sounds like you have some research to do.
5.0stanger is offline
Old 05-09-2007, 02:11 PM
PJB
PJB's Avatar
The Mark 7's use the same HO motor as Mustangs do.
PJB is offline
Old 05-09-2007, 02:14 PM
dasfonzie
dasfonzie's Avatar
I read only the LSC did, or is that the only one that had any kind of 5.0?
Old 05-09-2007, 02:57 PM
87ttopGT420
87ttopGT420's Avatar
mark vii come with the 5.0 ho
87ttopGT420 is offline
Old 05-09-2007, 05:49 PM
PJB
PJB's Avatar
I just did a quick look on ebay and it seems that all the Mark 7's had the HO 5.0, even the non LSC models.
I think the LSC models had an upgraded suspension but I might be wrong.
PJB is offline
Old 05-09-2007, 06:06 PM
nyfreakinrican7
nyfreakinrican7's Avatar
As far as I know the LSC had air suspension
nyfreakinrican7 is offline
Old 08-07-2007, 06:20 PM
Burnitup2k
Burnitup2k's Avatar
I believe 87 was the last year only the LSC had the HO. Afterwards they all recieved it.
Burnitup2k is offline
Old 08-07-2007, 06:51 PM
CrazyCobraSpeed
CrazyCobraSpeed's Avatar
ho 5.0s just have a different cam and a different firing order... u dont need nething else just the firing order need to be changed if u get a H/O cam
CrazyCobraSpeed is offline
Quick Reply: Building a non-Mustang 5.0
